Author Topic: StarAlignment issues  (Read 2107 times)
Offline Udo.Zlender
« on: 2015 March 27 07:49:04 »
Since a couple of days my StarAlignment refuses to work. When I try to register  series of 30 - 40 subs with default settings no alignment can be achieved. First I thought that shifts between frames were to large and I varied  settings in StarAlignment. No improvement resulted and I had the idea to align the frames with CometAlignment in a first run. That worked so far, but results were not as good as I expected. I than used these nearly aligned frames as new input to StarAlignment with a mysterious outcome.
In the original series coordinates of a certain star in the first image were 1996, 1434 and in the last 1967, 1432.
After CometAlignment there remained a drift of one pixel in x.
After the following StarAlignment the star was shifted to 1996, 1433, which are nearly its original unaligned  coordinates ???
Ideas welcome,
Udo
Offline Udo.Zlender
Re: StarAlignment issues
« Reply #1 on: 2015 March 27 08:56:24 »
In the mean time I found this topic
http://pixinsight.com/forum/index.php?topic=8312.0
and yes, it is a hot-pixel problem.
Thank you for reading,
Udo
