Author Topic: CosmeticCorrection Settings with Master Dark?  (Read 3379 times)
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« on: 2015 March 19 13:10:24 »
To date I have been using CosmeticCorrection with the Auto Detect routine and defined sigma ranges for rejection.  However using a Master Dark should give more precise control.  My question is, what are the guidelines for setting the hot pixel and cold pixel threshold parameters?
If anybody can explain or point me to a post that covers that, I would really appreciate the help.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline chris.bailey
Re: CosmeticCorrection Settings with Master Dark?
« Reply #1 on: 2015 March 20 00:51:17 »
Jim
I set mine applying a master dark CC correction to a copy of the master dark. Turn on RTM and adjust sigma until all the errant pixels in the master dark vanish.
Chris
ps I find using Autodetect to have an edge as I find there are several randomly hot/cold pixels on my CCD that don't appear in the master dark.
Offline jkmorse
« Reply #2 on: 2015 March 20 08:10:23 »
Chris,
Thanks.  I have been playing with the settings but like you, I seem to always get a cleaner image when using Auto Detect and thought I must be missing something in how I set the parameters with a Master Dark.  Still welcome others with possible solutions, those yours makes sense.
Jim
Apogee Aspen 16803
Offline Warhen
    • Billions and Billions
« Reply #3 on: 2015 March 24 12:57:33 »
Guys, Note that either by design, or serendipity that you can use both Auto Detect and the Master Dark methods. I find that AD at the default Sigma of 3 works very well for my data, but also using a Master Dark eliminates even more errant hot pixels. Just slide them away without being more aggressive than you need to be. Take the time to define column defects in the Use Defect List section below, and you will get a fabulous cosmetic correction after calibration!
Best always, Warren
Warren A. Keller
www.ip4ap.com
Offline Harry page
« Reply #4 on: 2015 March 24 13:06:57 »
Of course you may get some cosmic ray hits that are not in your darks !!
But the best way I have found is that I use a 20 min dark for all my CC (that are below 20 mins of course) even for say a 5 min
sub as there are usually more in the 20 min than is needed , but less errant hot pixels slip the net  8)
I find the auto version can work well but is slow
Harry
Harry Page
