Steve,
The issue is that you have different goals in that image. You want the background to be balanced as between RGB but you need to get rid of the green in the target and stars. In situations where only the target needs the adjustment I always apply a luminance mask to the image before applying SCNR. That way you protect the balanced background. Without the mask, your background has a reddish/purply hue.
Also, which settings are you using in SCNR. It makes a difference in how the tool attacks the green.
Jim
