Back some time I bought a used NEC MultiSync2490WUXi wide gamut monitor. Since then I've been calibrating it every 6 weeks using a Monaco OptixXR unit. I use Spectraview II software to calibrate and find that using the settings for photo editing leaves the images dark. I changed the contrast ratio in attempt to lighten the processing result. I could use some suggestions for settings to calibrate the monitor. My current setting is below: The contrast ratio was set to 350:1
![](http://)
