Author Topic: Crop Lum and RGB  (Read 2905 times)
Offline frasax
Crop Lum and RGB
« on: 2015 February 17 11:10:18 »
Hello,
i´d like to crop two (or more) already aligned Frames, the Luminance and the RGB Chanel. Is that possible and if yes, how?
CS Frank
Offline Zocky
Re: Crop Lum and RGB
« Reply #1 on: 2015 February 17 13:03:34 »
You can do that by using DynamicCrop tool.
Open all of your images. On the first image define crop area, than make a New Instance of that (drag the blue triangle on the workspace). Close DynamicCrop tool.
Now simply drag and drop the process icon on every image.
Offline frasax
« Reply #2 on: 2015 February 17 13:37:59 »
Ahhh Easy, Thank you!
CS Frank
Offline astrovienna
« Reply #3 on: 2015 June 07 10:00:57 »
A followup:  Can I save that process icon and call it up for use later?  When I try to reload it (from Process>Process Icons>Load Process Icons) PI tells me that all existing process icons will be lost.
Kevin
« Reply #4 on: 2015 June 07 10:46:18 »
Kevin
Use the Merge Process Icons.
« Reply #5 on: 2015 June 07 12:45:27 »
Hi Kevin, as Mike said use Merge icons. See here a video that shows that.
Saludos, Alejandro.
Offline astrovienna
« Reply #6 on: 2015 June 07 19:39:51 »
Thanks, Mike and Alejandro.
Kevin
