Author Topic: Calibration master building  (Read 3059 times)
Offline jeburnett
« on: 2015 February 16 05:58:55 »
I have huge stashes of calibration images that I’ve never built masters from because I’m too lazy to do them.  I’m wondering if PixInsight can (perhaps via some scripting) be coerced into diving into a pile of these and basically build separate masters using these classifications:
•   Filter type
•   Rotation angle
•   Temperature
•   Exposure duration
•   Binning
Lots of other tools exist for building masters but none that I’ve found pay any attention to rotation angle and I’m hoping this sort of thing is possible.
Jonathan
Offline jeburnett
Re: Calibration master building
« Reply #1 on: 2015 March 22 15:21:52 »
I guess then from the lack of replies that this is indeed something that PixInsight cannot do.
« Reply #2 on: 2015 March 22 15:52:54 »
PI can do it --- if you can do scripts in JavaScript. I guess this is something that you cannot do ;) . So the answers is that PI has no out-of-the-box tool to do this.
Offline jeburnett
« Reply #3 on: 2015 May 18 18:53:53 »
A description of technique and possibly an example to jump start would be appreciated.
Jonathan
Offline RickS
« Reply #4 on: 2015 May 18 20:08:02 »
The BatchPreprocessing script can already deal with filter type, duration and binning so with a bit of manual file sorting you can probably do it manually in batches.
Best place to start with this would be to learn some basic JavaScript and then read some of the existing scripts as examples.
Rick.
Offline cfranks
« Reply #5 on: 2015 May 20 17:48:02 »
If you have asymmetrical vignetting then you might need to worry about rotation angle for your master flats but not for bias nor dark masters.
Charles
