Author Topic: Hot Pixel Removal  (Read 2786 times)
Offline gspiegelman
Hot Pixel Removal
« on: 2015 February 10 06:59:05 »
I find that even after calibrating with fresh dark/bias frames I still have some pinpoints left - hot pixels. How can I get rid of them? In Maxim there is a Hot Pixel Removal tool. I would hate to leave PixInsight during processing, just to use Maxim to remove the Hot Pixels.
Offline CharlesW
Re: Hot Pixel Removal
« Reply #1 on: 2015 February 10 07:18:27 »
If you Google SDAA AISIG Pixinsight Image integration there is a pretty good Youtube about 1.25 hours long, that explains hot pixel removal using Cosmetic Correction. Fast forward till he starts talking, lots of dead time at first.
Offline bitli
« Reply #2 on: 2015 February 10 07:55:53 »
The tool you look for is CosmeticCorrection
Note that if you do dithering (make a small random move between images), any remaining hot/dead pixel will usually be rejected during integration.   Cleaning with CosmeticCorrection is still a good practice IMHO. Be sure that you just remove only the clearly hot/dead pixel (do not over do it).
-- bitli
Offline gspiegelman
« Reply #3 on: 2015 February 10 11:38:14 »
I realized this this morning when I went to process the images and saw the Cosmetic Correction check-box on the BatchPreProcessing script. I had completely forgotten about it from the first set of tutorials...
Thanks for your quick replies...
