Author Topic: Creating a New Folder in PixInsight  (Read 2735 times)
Offline llpastro
    • Sonoran Dark Skies
« on: 2015 February 07 08:00:08 »
I created a new folder in the Save As dialog and PixInsight could not save the image in that folder because it said it did not exist.  I went to file explorer to delete the folder and it said it couldn't find it either.  I rebooted the computer with no change.  Now I am stuck with a folder that I can see but cannot use or delete.  See the attached screen print from when I try to delete the folder.  This is a Win 7 machine.  Any suggestions?
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
Offline bitli
Re: Creating a New Folder in PixInsight
« Reply #1 on: 2015 February 07 08:11:27 »
    On windows you may some times have to press f5 so that windows realizes that you really created a folder...
Bitli
Offline llpastro
« Reply #2 on: 2015 February 07 10:00:11 »
That didn't seem to help.  Is there something I did wrong when creating the folder in PixInsight or is this a possible bug?  Regardless, I would still like to delete the folder.
Larry
« Last Edit: 2015 February 09 11:52:25 by llpastro »
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
Offline llpastro
« Reply #3 on: 2015 February 07 10:05:22 »
I was able to go back into PixInsight and went to File/Open and navigated to the folder that contained the offending folder, did a right click and delete and I was able to successfully delete the folder.
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
