Author Topic: pixinsight don't register my images  (Read 11146 times)
Offline ixio
Re: pixinsight don't register my images
« Reply #15 on: 2015 January 30 07:16:02 »
2 files fits is utopia for me,i have slow internet connection, 2 raw is best, where i upload the files?
« Last Edit: 2015 January 30 09:57:10 by ixio »
Offline ixio
« Reply #16 on: 2015 January 30 10:47:31 »
i post this screenshot,the setting on menĂ¹ is ok?we colud see on process console the trasformation matrix result for alignment and the movement between frame is near inesistent,dx dy.i want upload the 3 raw file but i don't know where?
ixio
Offline Zocky
« Reply #17 on: 2015 January 30 10:58:49 »
You can use, Dropbox, Google drive or some other file sharing service.
Offline ixio
« Reply #18 on: 2015 January 30 11:52:54 »
hi i have upload on dropbox some raw light files of m106 ,if the support or other people want download the files please send me a email for sharing the links
Offline Zocky
« Reply #19 on: 2015 January 30 12:01:59 »
Simply put the link in the post, and who wants to look will just download the files.
Offline Zocky
« Reply #23 on: 2015 January 30 13:30:49 »
Ixio, did you calibrate your images? There is a lot of hot pixels and probably that is the reason why your star alignment failed.
I have changed this 3 parameters in star detection, and it works fine. At least on this 2 images. I will run all 8 now, and see what will happened.
Offline Zocky
« Reply #24 on: 2015 January 30 14:06:19 »
And here it is, yours M106 ;)
Please take a note that this was quick and dirty processing, and that images were not calibrated.
Offline ixio
« Reply #25 on: 2015 January 30 14:31:23 »
uauuuuuu,this frame is not calibrated but only raw non calibrated,if i change these parameters i will register?i hope i try now!
Offline Zocky
« Reply #26 on: 2015 January 30 14:39:30 »
Before star alignment, you should do image calibration using your dark, bias and flat frame. After image calibration go to star alignment, and change settings in star detection window. There is possibility if you proper calibrate your frames, that you shouldn't have to change any of the parameters, because you will get rid of the hot pixels which now confuse star detection process.
Offline ixio
« Reply #27 on: 2015 January 30 14:57:31 »
it works thanks zocky,i calibrated the light whit a master dark very different on temperature  :D sorry but i don't think what happened
Offline Zocky
« Reply #28 on: 2015 January 30 15:01:00 »
Great :)
Now go to image integration, process that image and show us your result.
Offline ixio
« Reply #29 on: 2015 January 30 23:22:12 »
Ok
