Author Topic: Question on Comet Alignment Tool  (Read 2415 times)
Offline kerrywaz1
    • Spirit Bear Observatory
« on: 2015 January 25 19:44:14 »
I took a series of images of comet Lovejoy via a monochrome CCD using RGB filters as opposed to one-shot color.
I have watched Harry's video tutorial about Comet Stacking, but it appears to use a set of DSLR one-shot color images when processing. How do I go about processing the images taken with my monochrome setup? I have a set of Red, a set of Green and a set of Blue with the Red series taken first.
Thanks.
Deep Sky Instruments RC14C
FLI PL16803 w/MOAG + StarlightXpress Ultrastar
Pyxis 3"
Astro Physics AP1200
Tak FSQ-106EDXII
Apogee Alta F16M
Hap Griffin modified Canon EOS 5D Mark II
PixInsight, MaxIm DL, PhotoShop CS5
Re: Question on Comet Alignment Tool
« Reply #1 on: 2015 January 25 19:59:24 »
i think it should work the same - load everything into CometAlignment and mark the 1st/last images with the comet location, then create the registered frames.
then simply stack all the Rs, Gs, Bs etc. separately, then merge the 3 mono images to an RGB image per usual. they should all be registered to one another.
