Author Topic: XISF File Format - Second Draft Specification  (Read 6628 times)
« on: 2015 January 21 13:07:33 »
A new version of the XISF specification document (second public draft) is now available online:
      http://pixinsight.com/doc/docs/XISF-1.0-spec/XISF-1.0-spec.html
(you may need to refresh your browser). The entire PIDoc source code is also available:
      https://github.com/PixInsight/XISF-specification
I have included many suggestions and ideas received since the first draft document. The main changes are:
- Monolithic XISF units are now self-contained and restricted to a single .xisf file (no external references allowed in a monolithic XISF file).
- Planar and normal pixel storage models are now realizable (new pixelStorage XML attribute of the Image core element).
- Redesigned syntax of external XISF block locations.
- New/improved figures.
- Removed ambiguities between String16 and String8 Metadata properties (each Metadata property has now a unique mandatory data type).
- Hundreds of bug fixes and improvements.
- New layout thanks to the latest version of the PIDoc compiler script.
This document is now much more mature and accurate than the previous version, so it is a much better platform for discussion and collaboration. There are contributions that I am still evaluating (especially a new compression method suggested by Georg Viehoever) and will probably lead to a third version of the draft document in the incoming days.
A big thanks to everybody who are contributing to this project.
