Author Topic: DBE on lots of nebulosity?  (Read 5354 times)
Offline CharlesW
« on: 2015 January 16 21:26:12 »
Most DBE tutorials I've seen deal with a moderately sized Galaxy or nebula surrounded by lots of space. I just did 5 hours of the Rosette Nebula that fills about 97% of the frame. How do you DBE an image that is mostly nebulosity or do you DBE it at all? Is there a tutorial already in place?
Offline lucchett
Re: DBE on lots of nebulosity?
« Reply #1 on: 2015 January 18 13:24:16 »
Can you post a frame sample?
I did a first try on the same object at 1000 focal length and it was not easy.( for me...)
http://andrealucchetti.smugmug.com/Astrophotography/Astrophoto/i-2hWQz92/A
I can check if I retained the dbe process icon and share if you like to get it as a starting point, provided the framing is similar
In general, I try to find a very deep image as a guidance and put a few sample in the empty regions.
If you have complex gradients it will be hard, and optimal flats are required to easier things.
Andrea
Offline fulatoro
« Reply #2 on: 2015 January 18 15:59:44 »
Harry' s Astrished has a great tutorial on that. The second half of the tutorial deals with dbe on Nebulosity.
http://www.harrysastroshed.com/pixinsight/pixinsight%20video%20files/2013%20pix%20vids/dbe/dbe.mp4
Offline lucchett
« Reply #3 on: 2015 January 19 02:15:40 »
I may be wrong, but the issue with the image in the video is that in the area there is a "plateau" of faint nebulosity-dust. The samples in the lower right part (1/3 from corner) are risky in my opinion because they can possibly lead the model to cut this faint nebulosity.
If your image is very deep, this could be a problem.
In this case, you should try correcting your flats with super flats and compare the results to check if thre is further improvement for these areas.
Andrea
Offline bitli
« Reply #4 on: 2015 January 19 06:54:46 »
This is a difficult problem.  You can try to take just a couple of images of a dark area near the original location, preferably when doing the original image (maybe just before and just after to have about the same illumination), make a DBE on that one, and apply the generated correction to the original image, with some factor.  YMMV.  If you have some stable dust donuts or remaining vignetting not fully corrected by the flat, this may help. Sky gradient may be more difficult.
In DBE you can force the value of the samples and use the DBE algorithm only to create the smooth image to subtract/divide. I used this with some script when I had other source of information on the problem (remaining amplifier glow), but this is lengthy to say the least and rely on your estimation of the correction to apply.
-- bitli
Offline Harry page
« Reply #5 on: 2015 January 19 10:13:27 »
Please let us see the problem image and then we can offer a solution
Harry
Harry Page
Offline topboxman
    • Peter's Gallery
« Reply #6 on: 2015 January 19 10:23:13 »
Try ABE using default settings. It seems to work well on heavy nebulous objects.
Peter
Offline CharlesW
« Reply #7 on: 2015 January 19 10:47:39 »
I've attached my Ha master in 7zip. First time attaching an image here so hopefully it's useable. Thanks for whatever advice you may be able to give.
Offline Harry page
« Reply #8 on: 2015 January 19 12:28:21 »
This is a very small Image is this correct ?
Harry
Harry Page
Offline CharlesW
« Reply #9 on: 2015 January 20 10:04:34 »
Sorry for being such newb. Here is a Dropbox link with the full size xsif. https://www.dropbox.com/s/195grfudium8a1r/light-FILTER_Ha-BINNING_1.xisf?dl=0
Offline Harry page
« Reply #10 on: 2015 January 21 13:33:17 »
Being it a ha image you need very little DBE , like 5 samples  :D
Harry
Harry Page
Offline CharlesW
« Reply #11 on: 2015 January 21 14:22:31 »
Thanks, much appreciated.
Offline lucchett
« Reply #12 on: 2015 January 22 00:59:37 »
Harry,
I take the chance to ask a question on this, just to be sure.
I see you placed the samples in the best areas but nontheless there is still very faint nebulosity in these areas.
the model will consider this as gradient and try to flatten , right?
I assume this is not avoidable...
thanks for clarifying!
Andrea
