Esteemed colleagues,
I am using PixInsight to postprocess the output of DeepSkyStacker (originally coming from a Canon 60Da). It works well, but the DeepSkyStacker Autosave.tif file is very dark when opened with PixInsight, as if it weren't using the whole bit depth of its file format. I can manually adjust it with Intensity Transformations -> Histogram Transformation but was wondering if there was a shortcut.
Also, I am under the impression that if I adjust brightness, saturation, etc., in DeepSkyStacker and save the file, it doesn't have as much bit depth as it claims to. I see banding in shaded areas, for instance. This was described as a problem with earlier versions of DeepSkyStacker some time back; does anyone know if it's still present?
I am using the latest DeepSkyStacker, version 3.3.4.
Thanks!
