Author Topic: PJSR: new Matrix(Matrix A) crash?  (Read 4236 times)
Offline mschuster
« on: 2015 January 02 11:37:57 »
Hi Juan,
I assumed this constructor gives copy, but I see a crash on Win 7 1123.
var m1 = new Matrix([1, 0, 0, 2], 2, 2);
var m2 = new Matrix(m1);
*** Error [000]: <...>/test.js, line 3: Error: At address 000000014011CBDA with exception code C0000005 :
Access violation: invalid memory read operation at address FFFFFFFFFFFFFFFF
Re: PJSR: new Matrix(Matrix A) crash?
« Reply #1 on: 2015 January 02 13:42:03 »
Bug confirmed. The constructor:
new Matrix( Matrix A[, int startRow, int startCol, int rows, int cols] )
and the method:
void Matrix.assign( Matrix A[, int startRow, int startCol, int rows, int cols] )
are broken. This is a regression in the latest versions of PixInsight 1.8. I'll fix this in the next version. In the meanwhile, you can use the following workaround:
Matrix.prototype.clone = function()
   return (new Matrix( 0, this.rows, this.columns )).add( this );
Example:
var m2 = m1.clone();
Sorry for the trouble.
