Author Topic: coversion problem  (Read 4301 times)
Offline Harry page
coversion problem
« on: 2014 December 29 06:36:12 »
I have combined 3 rgb fits images into a single image , I then go to save this as a 32 bit xisf file
All it saves is nothing i.e zero data !!!!
Repeatable
Regards
Harry
Harry Page
Offline Harry page
Re: coversion problem
« Reply #1 on: 2015 January 01 08:35:23 »
so no one else gets this ?????????????
Harry
Harry Page
« Reply #2 on: 2015 January 01 10:06:54 »
Harry,
I've never tried to save 3 images into a single file. If you could describe how you are doing that then I'd be more then happy to test on my Windows 7 system.
Offline Harry page
« Reply #3 on: 2015 January 01 10:10:12 »
Perhaps I explained poorly , sorry    :o
I took each of my masters of the red-green-blue and used channel combination to create a master RGB image ( all in fits)
I then saved it in the new format , but the new file contains no information when opened !!
Harry
Harry Page
« Reply #4 on: 2015 January 01 12:15:16 »
Harry,
I had no problem combining R,G and B, save as 32 bit floating xisf. Close PI. Open PI and loaded new image.
Offline Harry page
« Reply #5 on: 2015 January 01 14:41:04 »
Thanks for looking . I will try some other files as it does it every time with the one I have
Harry
Harry Page
« Reply #6 on: 2015 January 02 01:47:46 »
Hi Harry,
maybe you share the problematic file and see what others find out?
« Reply #7 on: 2015 January 03 08:27:17 »
Bug confirmed.
It only happens with 32-bit integer images. Files are written correctly, but the XISF module does not load 32-bit integer data correctly.
I'll fix this problem when I return home next week. The workaround is: Save the images in 32-bit or 64-bit floating point format. Sorry for the trouble.
Offline Harry page
« Reply #8 on: 2015 January 03 10:14:00 »
Sorry I did not submit details the 32 bit file correctly
But at least I am not mad
It will wait till you come back
Harry
Harry Page
« Reply #9 on: 2015 February 06 04:09:43 »
This bug is now fixed. I have just released an update for all platforms.
Thank you for your patience.
