I need your help - I dont understand the infos in the console by ImageIntegration.
Example
Reference Image:
Scale factors : 1.00000
Zero offset : +0.000000e+000
Noise estimates : 4.3860e-004
Weight : 1.00000
Image n1:
Scale factors : 0.98546
Zero offset : -7.506262e-005
Noise estimates : 4.4090e-004
Weight : 1.01902
Image n2:
Scale factors : 0.98720
Zero offset : -1.086849e-004
Noise estimates : 4.4150e-004
Weight : 1.01267
Q1:
What means Scale factors - is it the multiplier for the stacking?
Q2:
What is the Zero offset?
More or less light in the image, factor for transparency, ...
Q3:
Noise estimtes - assumption: the higher the number, the higher the noise of the singel image.
In the example, the Referenz Image has a lower Noise as Image n1 (4.3860e-004 < 4.4090e-004).
Nevertheless, the Scale factor and the Weight is higher in image n1 as in the Referenz Image.
Q4:
Weight - is it the multiplier for a single image in the integration process?
If yes - why is the weight in Image n2 higher as in the Reference Image, even though the noise is higher in compare to the Reference Image.
I cant find infos to this questions in the documentation (the factors are listed, but there are no practical infos).
The answers to my questions probably anywhere in the forum threads - but I cant find it.
Any support is welcome.
Best regards.
Herbert, Austria
