Author Topic: RGB .xisf Files from BatchPreprocessing after Updates  (Read 2565 times)
Offline jerryyyyy
    • Astrobin Images
« on: 2014 December 23 11:19:56 »
Have finally got some new data to process and not that after all the updates my files from BatchPreprocessing come in as RGB .xisf files.  Have to convert to greyscale.  Is this normal?
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Re: RGB .xisf Files from BatchPreprocessing after Updates
« Reply #1 on: 2014 December 24 09:40:51 »
Hi jerryyyyy, I don't know if I interpret well but if your input images are RGB images from a DSLR the expected result will be an RGB image
Saludos, Alejandro.
Offline jerryyyyy
    • Astrobin Images
« Reply #2 on: 2014 December 29 07:29:53 »
I we are finally able to image under clear skys in California and I have this same minor problem again.  Collected CCD images last night for RGB and H-Alpha of the Horsehead and after stacking with BPP the images came in as RGB, but I discovered the BPP was set for DSLR images from previous work... saved icons.
Duh!
Takahashi 180ED
Astrophysics Mach1
