Author Topic: Unable to launch multiple instances in Mac OS 10.9  (Read 2561 times)
Offline Howard
    • Cabin in the Sky Observatory
« on: 2014 December 18 23:04:27 »
Hi:
I am unable to launch multiple instances of PixInsight in Mac OS 10.9, having recently upgraded from 10.7 and installed the latest release of PixInsight. Prior to the upgrades, I could use the command !!$PXI_BINDIR/PixInsight -n from the PixInsight Process Control window, but BINDIR now seems to point to the wrong directory, and !!$PXI /Applications/PixInsight/PixInsight -n does not work either: in both cases I get the error message "Unable to execute external process:".
Many thanks for any help with this.
Howard.
Obsessed with the photographic experience of the cosmos!
Cabin in the Sky Observatory: PlaneWave CDK17, Paramount ME, Apogee U16M, Astrodon filters & MOAG, Starlight Lodestar, in a roll-off roof under the deep, dark skies of rural BC Canada.
Re: Unable to launch multiple instances in Mac OS 10.9
« Reply #1 on: 2014 December 20 01:48:40 »
Hi Howard,
The OS X distribution of PixInsight has changed recently. Try with PXI_COREDIR:
!!$PXI_COREDIR/PixInsight -n
This works on all platforms.
Offline Howard
« Reply #2 on: 2014 December 20 11:05:58 »
Hi Juan:
That does it, thank you! Is there some documentation on such environment variables?
I hope I can trouble you with one more basic question - when I save a new image, PixInsight no longer uses the the image window name as a default for the filename, as was previously the case. I found that to be a very convenient default, is there a preference setting to recover that?
Many thanks,
Howard.
