Hello,
recently I switched from Mac OS X 10.10 to PCBSD-10 (10.1.1RC2) with KDE desktop.
PixInsight Version is:
PixInsight Core 01.08.03.1123 Ripley (x64)
After configuring "Compositing type" to XRender and "Qt graphics system" to Native (PC-BSD Control Panel -> Desktop environment -> Desktop Effects - KDE Control Module -> Advanced), the "No compositing window manager" in PixInsight disappeared.
Package icu-53.1 is installed.
Starting PI:
Unable to load library icui18n "Cannot load library icui18n: (Shared object "icui18n" not found, required by "PixInsight")"
Yesterday I got a hint that PI wants to have libicui18n.so.52 (please don't ask from which ldd or similar command I got that - unfortunately I forgot it
![Roll Eyes ::)](http://pixinsight.com/forum/Smileys/default/rolleyes.gif)
), so I put the following line into /etc/libmap.conf:
libicui18n.so.52 libicui18n.so.53
That changed the PI starting output to:
Unable to find symbols in icui18n
PI is installed as root with predefined parameters, so it resides under /opt/PixInsight.
When I try to install the updates within PI, after the restart of PI the following message appears:
Unable to install updates: Can't execute the PixInsight Updater (stage 2) application.
After doing some research including the use of truss, it seems the execution of /tmp/PixInsight64-update/updater2/updater2 with the permissions of the user fails:
47685: execve("/tmp/PixInsight64-update/updater2/updater2", [ "/tmp/PixInsight64-update/updater2/updater2", "47681", "/opt/PixInsight", "/tmp/PixInsight64-update/
contents", "--restart" ], [ "mad=ImageWindow.activeWindow.currentView.image.MAD()", "avgdev=ImageWindow.activeWindow.currentView.image.avgDev()", "stddev=ImageWindow.acti
veWindow.currentView.image.stdDev()", "median=ImageWindow.activeWindow.currentView.image.median()", "mean=ImageWindow.activeWindow.currentView.image.mean()", "max=ImageWi
ndow.activeWindow.currentView.image.maximum()", "min=ImageWindow.activeWindow.currentView.image.minimum()", "PXI_CABUNDLEFILE=/opt/PixInsight/library/ca-bundle.crt", "PXI
_DOCDIR=/opt/PixInsight/doc", "PXI_LIBDIR=/opt/PixInsight/lib", "PXI_SRCDIR=/opt/PixInsight/src", "PXI_INCDIR=/opt/PixInsight/include", "PXI_RSCDIR=/opt/PixInsight/rsc",
"PXI_ETCDIR=/opt/PixInsight/etc", "PXI_BINDIR=/opt/PixInsight/bin", "PXI_APPDIR=", "PXI_BASEDIR=/opt/PixInsight", "PXI_COREDIR=/opt/PixInsight/bin", "PXI_COREFILE=/opt/Pi
xInsight/bin/PixInsight", "XTERM_SHELL=/bin/csh", "TERMCAP=xterm|X11 terminal emulator:@7=\EOF:@8=\EOM:F1=\E[23~:F2=\E[24~:K2=\EOE:Km=\E[M:k1=\EOP:k2=\EOQ:k3=\EOR:k4=\EOS
:k5=\E[15~:k6=\E[17~:k7=\E[18~:k8=\E[19~:k9=\E[20~:k;=\E[21~:kI=\E[2~:kN=\E[6~:kP=\E[5~:kd=\EOB:kh=\EOH:kl=\EOD:kr=\EOC:ku=\EOA:am:bs:km:mi:ms:ut:xn:AX:Co#8:co#80:kn#12:l
i#24:pa#64:AB=\E[4%dm:AF=\E[3%dm:AL=\E[%dL:DC=\E[%dP:DL=\E[%dM:DO=\E[%dB:LE=\E[%dD:RI=\E[%dC:UP=\E[%dA:ae=\E(B:al=\E[L:as=\E(0:bl=^G:cd=\E[J:ce=\E[K:cl=\E[H\E[2J:cm=\E[%i
%d;%dH:cs=\E[%i%d;%dr:ct=\E[3g:dc=\E[P:dl=\E[M:ei=\E[4l:ho=\E[H:im=\E[4h:is=\E[!p\E[?3;4l\E[4l\E>:kD=\E[3~:ke=\E[?1l\E>:ks=\E[?1h\E=:kB=\E[Z:le=^H:md=\E[1m:me=\E[m:ml=\El
:mr=\E[7m:mu=\Em:nd=\E[C:op=\E[39;49m:rc=\E8:rs=\E[!p\E[?3;4l\E[4l\E>:sc=\E7:se=\E[27m:sf=^J:so=\E[7m:sr=\EM:st=\EH:ue=\E[24m:up=\E[A:us=\E[4m:ve=\E[?12l\E[?25h:vi=\E[?25
l:vs=\E[?12;25h:kb=\010:", "LOGNAME=ecky", "XTERM_LOCALE=en_US.UTF-8", "XTERM_VERSION=XTerm(314)", "DISPLAY=:0", "WINDOWID=77594638", "TERM=xterm", "GTK2_RC_FILES=/etc/gt
k-2.0/gtkrc:/usr/home/ecky/.gtkrc-2.0:/usr/home/ecky/.kde4/share/config/gtkrc-2.0", "GTK_RC_FILES=/etc/gtk/gtkrc:/usr/home/ecky/.gtkrc:/usr/home/ecky/.kde4/share/config/g
tkrc", "SESSION_MANAGER=local/Deadman:/tmp/.ICE-unix/1570", "KDE_MULTIHEAD=false", "KDE_SESSION_VERSION=4", "GS_LIB=/usr/home/ecky/.fonts", "LANG=en_US.UTF-8", "XDG_DATA_
DIRS=/usr/local/share:/share:/usr/share:/usr/local/share:/usr/share:/usr/local/share:/usr/local/share/gnome", "XAUTHORITY=/tmp/.PCDMAuth-a1d3448930d29b5293bc", "MAIL=/var
/mail/ecky", "PATH=/usr/local/share/pcbsd/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/usr/home/ecky/bin", "QT_PLUGIN_PATH=/usr/home/ecky/
.kde4/lib/kde4/plugins/:/usr/local/lib/kde4/plugins/", "KDE_SESSION_UID=1001", "PWD=/opt/PixInsight/bin", "XDG_CURRENT_DESKTOP=KDE", "GROUP=ecky", "DBUS_SESSION_BUS_ADDRE
SS=unix:path=/tmp/dbus-8WUlOAcdzH,guid=4b776dfa7d55d6eef990bf6554ccd8db", "XCURSOR_THEME=Jimmac", "PCDM_SESSION=KDE", "HOME=/usr/home/ecky", "USER=ecky", "WINDOWPATH=9",
"SHELL=/bin/csh", "USERNAME=ecky", "LC_ALL=en_US.UTF-8", "KDE_FULL_SESSION=true", "XDG_CONFIG_DIRS=/usr/local/etc/xdg:/etc/xdg:/usr/local/etc/xdg:/usr/local/etc/xdg/xfce4
", "MOZ_DISABLE_IMAGE_OPTIMIZE=1", "RC_PID=21", "SHLVL=2", "QT_IM_MODULE=compose", "HOSTTYPE=FreeBSD", "VENDOR=amd", "OSTYPE=FreeBSD", "MACHTYPE=x86_64", "HOST=Deadman",
"EDITOR=vi", "PAGER=more", "BLOCKSIZE=K", "CLICOLOR=true", "MORE=-erX", "MANPATH=/usr/share/man:/usr/local/man:/usr/share/openssl/man:/usr/local/lib/perl5/site_perl/man:/
usr/local/lib/perl5/5.18/perl/man", "LD_LIBRARY_PATH=/opt/PixInsight/bin/lib:/opt/PixInsight/bin" ]) ERR#13 'Permission denied'
# ls -l /tmp/PixInsight64-update/updater2/updater2
-rwxr-xr-x 1 ecky wheel 1829497 Feb 1 00:15 /tmp/PixInsight64-update/updater2/updater2
Any help appreciated.
Many thanks,
E.
