Author Topic: Newby Questions  (Read 3492 times)
Offline DDolan1075
Newby Questions
« on: 2014 November 25 22:25:33 »
As somebody who is just starting to get the hang of working with PixInsight on the most basic level, I have some questions that I can't really find the answers to:
1) How do I know what processes and scripts need to be used on linear, non-linear, or both types of files.
2) I have been looking for a way to save a functional workflow check list, where I can load the image, load the list and start clicking on the individual items and having the process or script load on the workspace, ready to be used on the loaded picture.  A friend told me that he saw somebody had loaded the icons in order on the workspace  and saved the workspace.  Then loaded the workspace and loaded a picture and started running through the workflow without having to go looking for his favorite processes.  I am not sure how to save a workspace and reload it later with all of the active processes ready to be used.
3)I have been using the Channel extraction/linear fit/channel combination tools where I am using the color with the highest mean value as the reference for linear fit tool on the other two colors before recombining with some nice results.  I am interested to know what effect that has with ABE, Background Neutralization, and Color Calibration.
4) When do you need to link the the automatic stretch function as opposed to letting them stretch each channel?  When do you not auto stretch the linear images?
I will stop at this point and follow up with other questions based on responses.
thanks,
Dave
Offline oldwexi
    • Astronomy Pages G.W.
Re: Newby Questions
« Reply #1 on: 2014 November 26 06:34:26 »
Hi Dave!
Answers to most of your questions from my biased point of view you get by downloading
"Jim`s PixInsight Cribsheet" from Jim Morse"
http://pixinsight.com/forum/index.php?topic=7583.msg50500#msg50500
Answer to 2)  Use Save Project and Load Project (Under the FILE Tab....)
                    Also in the History Explorer there are all process steps of one/each image visible, if you move the triangle
                    of this process sequence to the workspace, you get an process container which can be used as a macro and saved wihtout the images.
Gerald
Offline sreilly
Re: Newby Questions
« Reply #2 on: 2014 November 26 07:08:41 »
Just to add to Gerald's post, I think you will find that each image will require different processing depending on the equipment or object. What I have done for my purposes is load the process icons I use most and usually in my logical order and save them as my Favorites noting the location of that saved file and edit the startup script to load the icons when PI starts. See here for the thread on doing so http://pixinsight.com/forum/index.php?topic=1649.0
-Steve
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline DDolan1075
Re: Newby Questions
« Reply #3 on: 2014 November 26 11:02:33 »
thank you both for your responses!  I have printed Jim's  Cribsheet and have started a notebook to save this information.
