Author Topic: Unable to drag file to open  (Read 4270 times)
Offline Torsinadoc
« on: 2014 November 25 04:02:18 »
I downloaded the newest update (mac).  I am no longer able to drag an image file to PI workspace to open the image.
PixInsight Core 01.08.03.1123 Ripley (x64)
Copyright (C) 2003-2014 Pleiades Astrophoto
Welcome to PixInsight. Started 2014-Nov-25 12:00:13 J2456987.00015 UTC
* Parallel processing enabled: Using 8 logical processors.
* Thread CPU affinity control enabled.
* PSM AutoSave enabled. Auto-save period: 30 seconds.
open "file:///.file/id=6571367.5252046"
Reading 1 file(s):
*** Error: Unknown or unsupported file type:
** No files were loaded.
This occurs with fit, tiff, jpg, etc.
I can open the image by using the drop down menu
Offline Philippe B.
    • CIEL AUSTRAL
Re: Unable to drag file to open
« Reply #1 on: 2014 November 28 00:43:07 »
I think I saw the same issue on my 2 mac (OSX Yosemite)
Offline carlosGR
« Reply #2 on: 2014 November 29 02:53:07 »
I have the same problem, iMac 27 (2011) with yosemite 10.10.1
Reading 1 file(s):
file:///.file/id=6571367.997453
« Reply #3 on: 2014 December 01 14:23:49 »
"file:///.file/id=6571367.997453" is what Apple calls a "file reference URL" (see for example this document). It seems that OS X 10.10 has changed the way file references are sent to applications...
From what I have read, OS X 10.10 is causing application compatibility problems. For this reason we have not updated our machines, which continue running 10.9.5 for now (installing .0 OS X versions is almost invariably a serious error IMHO). Right now I have no idea of what's happening, but will try to find a solution. The workaround is obvious: double click on the workspace to open files.
Offline gvanhau
« Reply #4 on: 2014 December 15 13:07:49 »
Only a complement:
In Windows if I try to drag a file from a remote drive to PI, I get a simmilar error.
If I instead map the drive locally it works ok.
Regards
Geert
Geert Vanhauwaert
