Author Topic: New script: ColorMask  (Read 81913 times)
Re: New script: ColorMask
« Reply #45 on: 2015 September 20 06:01:15 »
Rick
Could you add a color bar like ColorSaturation has? Here is what I had in mind. And just for the record this image was done completely in PixInsight.
Offline llpastro
    • Sonoran Dark Skies
« Reply #46 on: 2015 September 20 07:29:45 »
To update from version 0.3 to 0.4 do I need to first remove 0.3?  Or can both reside together in PI?
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
« Reply #47 on: 2015 September 20 07:37:25 »
Hi Larry, when you unzip it you will see that it has a different name (previous: ColorMask, new: ColorMask 04, so you can maintain both, or remove the previous one and add the new one.
Note that the version 0.4 when you open the script says 0.3
Saludos, Alejandro.
« Reply #48 on: 2015 September 20 11:25:15 »
I missed version 0.4 some how.  :o
It would still be nice to have the color bar.
« Last Edit: 2015 September 20 11:56:39 by msmythers »
Offline RickS
« Reply #49 on: 2015 September 20 14:42:04 »
Mike,
I have a long list of suggestions for improvements and a colour bar is certainly one of them.  I'll have to set aside a few evenings and just get them all done.  I have a large backlog of images to process so it is hard to find the time!
If I change things too much Warren will curse me  :D
Rick.
« Reply #50 on: 2015 September 20 15:06:22 »
I understand priorities! Images ;D
Offline Geoff
« Reply #51 on: 2015 September 20 19:39:19 »
Mike,
Rick.
Hi Rick
Just a minor point. Reduce the number of decimal places showing in the Process Console.
Geoff
Don't panic! (Douglas Adams)
Offline RickS
« Reply #52 on: 2015 September 20 21:05:33 »
Hi Rick
Geoff
Will do, thanks Geoff.
Offline WesChilton
« Reply #53 on: 2015 December 29 09:42:28 »
Rick, thank you very much for sharing the script it was very helpful in salvaging some pretty awful data I got on the rosette! I definitely went overboard and pushed this data too hard, but its still a much better result than I had previously. I still have MUCH to learn!
http://www.astrobin.com/231900/E/
Offline RickS
« Reply #54 on: 2015 December 29 16:11:37 »
Colours look pretty good, Wes.
Offline rdryfoos
« Reply #55 on: 2016 January 16 07:00:51 »
Rick,
This opens some interesting doors!
How do you add the script to PixInsight?--I get all kinds of errors--I put in in the repository--no go.
Offline RickS
« Reply #56 on: 2016 January 16 15:57:17 »
In case you missed it in the other thread, Rob Pfile was kind enough to point you here: http://pixinsight.com.ar/en/docs/2/pixinsight-add-script.html
Rick.
Offline patthehorse
« Reply #57 on: 2016 June 04 10:51:52 »
Just added your script to my PI (ver0.7) It works very well, even if I don't fully understand it. Being able to mask a colour and adjust the others in my NB images using the hue in Curves is brilliant. A big thanks for all your effort.
Pat.
SW200p, Atik 314L+, AZ EQ6-GT.
Guiding ST80, ASI130mm.
Un-Stable Obs.
Clear skies all.
Offline RickS
« Reply #58 on: 2016 June 04 18:05:35 »
Pat.
I'm glad you found it helpful, Pat!
Rick.
Offline patthehorse
« Reply #59 on: 2016 June 07 20:50:10 »
Very helpful and fun playing with it. Still smiling and transforming old images. Brilliant! :)
Un-Stable Obs.
Clear skies all.
