Author Topic: Processing Example in PixInsight Core 1.2: M45 (The Pleiades Cluster)  (Read 22702 times)
Offline lucchett
Question about DBE and pseudo flat subtraction
« Reply #15 on: 2008 December 25 14:08:57 »
Hi Carlos,
I have a question:
as you are dealing with linear data in this tutorial (DSLR, right?), why do you subtract your background instead of dividing?
Is this related to the Pixinsight implementation of DBE or do you have any particular reason?
Andrea
« Reply #16 on: 2008 December 25 14:11:39 »
doing DBE is not the same as flat fielding and IMO it does not replace it. You can apply a perfect flat field and still have gradients left over which DBE can handle. On the other hand if you did not apply a flat field then DBE can't fix the illumination differences.
« Reply #17 on: 2008 December 25 15:12:24 »
Hi Andrea and Sander,
Because light pollution gradients are additive effects: they accumulate during the whole exposure time. Vignetting, on the other hand, is a multiplicative effect: it is a constant function that modifies the illumination distribution, independently on exposure time. For this reason, to correct for vignetting we multiply the image by the inverse of a special control frame that mimics the distribution of illumination on the focal plane.
Additive effects are in general impossible to predict, so the only way of removing them efficiently is to build and subtract a model of the illumination irregularities in the image. Fortunately, in deep-sky images we have a perfectly constant reference: the sky background. Since the sky background is constant (read flat), we can place samples on background areas of the image to build an accurate background model, which reproduces the existing illumination irregularities. DBE and ABE are two sophisticated image processing tools to build background models in PixInsight.
Note that background modeling and correction of multiplicative or additive effects have nothing to do with linearity of the data.
Actually not the same, but only for practical/methodological reasons. In theory, a synthetic background model could be as good as a natural flat frame. In practice, however, a natural flat frame is always preferable for two main reasons:
- When building a synthetic model, we can't isolate additive from multiplicative effects when both are present, as usually happens.
- Making an accurate flat frame is in general very easy, while building an accurate synthetic model is a delicate task, and sometimes it's almost impossible. For example, when there are very few background areas, we can make just an approximation based on marginal data (which is much better than nothing, of course :) ).
Offline lucchett
« Reply #18 on: 2008 December 25 16:54:06 »
Thanks Juan & Sander.
So, as I do take flat field frames (that I use to calibrate my images), if I want also to correct complex sky gradient using DBE I need to "subtract" .
I was mistaking!
Andrea
« Reply #19 on: 2008 December 25 18:01:08 »
You got it Andrea. Different tools, different applications.
