Author Topic: PixInsight 1.8.3 Ripley: Enhanced Parallel Swap File Storage  (Read 22534 times)
The upcoming version 1.8.3 of PixInsight comes with an improved parallel swap file storage management. In previous versions, only one swap storage file could be generated per drive (physical or virtual). Clearly this was suboptimal for SSD disks and virtual RAM drives.
In the new version, one can select the same swap storage directory multiple times, as shown in the next screenshot.
In this screenshot, the same physical device (an SSD in this case) is being used with four concurrent I/O threads. The new swap file storage management routines implemented in version 1.8.3 are optimized for parallel I/O operations on fast SSD and RAM devices. The performance gain that can be achieved with this new feature is spectacular on all platforms. The following benchmarks have been performed on the Antares reference workstation (Intel Xeon E5-2695 v2 @ 2.40GHz, 64 GiB of RAM, Fedora 20 64-bit Linux) with PixInsight Core 1.8.3.1115:
0TNZ014338A70855X9M9NAP6BLHW41JN - 4 threads on a Samsung SSD EVO 840 1TB
Performance indexes: total=12983 cpu=12133 swap=18342 (3311.650 MiB/s)
JEXKR496O859I3213BIG56MV17G67769 - 4 threads on the system /tmp directory (Linux tmpfs)
Performance indexes: total=13814 cpu=12194 swap=30877 (5574.920 MiB/s)
The new parallel storage subsystem yields spectacular I/O transfer rates above 3.23 GiB and 5.44 GiB, respectively for the physical SSD and virtual RAM drives in these benchmarks. The good news is that similar improvements can now be achieved on all platforms, including Windows and Mac OS X, although the Linux kernel remains hard to beat in these tasks.
Version 1.8.3 of PixInsight is now undergoing the last testing stages and should be released in a few days for all supported platforms.
Offline NGC7789
Re: PixInsight 1.8.3 Ripley: Enhanced Parallel Swap File Storage
« Reply #1 on: 2014 October 24 07:55:26 »
This is very nice. Got to love getting better performance out of existing hardware.
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« Reply #2 on: 2014 October 25 14:36:27 »
Juan,
Like I said before, I love the Fall cause you always grace us with a new set of upgrades and new toys to play with.   ;D
Thanks for the early Christmas presents.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline NGC7789
« Reply #3 on: 2014 October 26 08:42:58 »
Juan,
I've got a few questions about the upcoming parallel swap feature. Using a combination of RAM disk and SSD swap I already get about 4600 MiB/s swap performance. Can you multi-thread swap on multiple sources? How many threads should one create? Is it related to the number of cores? Is the a tradeoff between swap threads and the cores that are available for other processing tasks? Some guideliness one setting up the new feature will be most appreciated. Of course, I will probably end up experimenting on my own anyway  ;D
-Josh
« Reply #4 on: 2014 October 26 14:45:14 »
Hi Josh,
Yes, this is now possible with 1.8.3. As expected, the best results are always achieved with multithreaded swap storage on RAM disks (Linux tmpfs for example), but any configuration is now possible.
I think it's more related to the I/O bandwidth of the device(s) involved. For example, with Linux tmpfs on the Antares workstation we achieve a maximum of transference speed of about 6 GiB/s with 5 - 6 threads. With SSD disks connected to motherboard SATA ports it seems that 4 threads are about optimal.
Not at all. The swap I/O routines never work in parallel with other tasks. The whole PixInsight platform gets 'freezed' during a swap read or write operation. This may change in a future version, but not in the middle term.
As you say, once we release 1.8.3 you'll have to experiment to find the optimal settings for your system. It all depends on your hardware and on the volume of the data you process.
Offline NGC7789
« Reply #5 on: 2014 October 31 11:44:08 »
Juan,
I've been experienting with swap benchmarks since the new release and I have some observations to share.
1. I've noticed a slight difference depending on the order the swap threads are declared (only about 1.5% but very repeatable). If they are ramdisk first (say ramdisk/ramdisk/ssd/ssd or ramdisk/ssd/ramdisk/ssd) it performs a bit better than the other way around. Is this expected that the order matters, albeit only a tiny amount?
2. Is there any reason to consider an unequal number of thread per source? I experimented with it and it was always slower so I think not. But if not I would propose a different interface where you choose sources (only once) and then separately the number of threads per source. This would be both a simpler interface and remove the temptation to give an unequal number of threads.
3. I assume the total available swap space is still the smallest swap source times the number of sources. Threads don't matter here, right?
4. Overall with 1.8.3 I am seeing the CPU score about 1% slower regardless of swap setting.
-Josh
Offline jkmorse
« Reply #6 on: 2014 November 04 13:21:44 »
Juan,
For what its worth, I am seeing substantial performance and speed improvements under Windows 8.1, even under the base package.
Jim
Apogee Aspen 16803
Offline slang
« Reply #7 on: 2014 November 13 05:06:16 »
Hi Juan.
I have 3 temporary directories defined
/mnt/sdb1
/mnt/sdc1
/mnt/sdd1
and as they're fast drives, I leave them alone.
Default swap speed is 2916 today before config update.
I've gone back to my original post/config (to remember the tweak) - http://pixinsight.com/forum/index.php?topic=7083.msg47979#msg47979 Made those changes (incl. the important sysctl -p)
and with the parallel i/o in 1.8.3 I get
Execution Times
Total time ............. 01:33.31
CPU time ............... 01:27.54
Swap time .............. 00:05.70
Swap transfer rate ..... 2908.379 MiB/s
Performance Indices
Total performance ......  5041
CPU performance ........  4324
Swap performance ....... 16108
These new stats are within 10% (or so) of my previous test from the link above.
What I deduce from this is that with that kernel tuning in place, the disk i/o is so heavily cached, that the bottleneck is system RAM and o/s calls, and that parallelising i/o doesn't help me here. I can tell the disk isn't being touched during this process too, no lights, no clicky clicky whir whir.
Even if it doesn't appear to help me much, it is great that this exists as it seems to help some platforms significantly.
Cheers -
Mounts: Orion Atlas 10 eq-g, Explore Scientific G11-PMC8
Scopes: GSO RC8, Astrophysics CCDT67, ES FCD100-80, TSFLAT2
Guiding: ST80/QHY OAG/QHY5L-II-M
Cameras: Canon EOS 450D (IR Mod), QHY8L, QHY163m/QHYFW2-US/Astronomik LRGBHaSiiOii
Offline NGC7789
« Reply #8 on: 2014 November 13 09:58:03 »
Hi Slang. Just to be clear, did you set up multiple entries for each swap drive (at least 2 per)? That would be necessary to benefit from the new swap thread feature. I had also tuned my Ubuntu along the lines of your other post and definitely saw benefit with the new swap feature.
Offline slang
« Reply #9 on: 2014 November 13 12:01:13 »
Hiya.
Yes.
I have a SSD boot drive. 3 x WD Raptors as cache drives. I have 6 entries;
/mnt/sdb1/scratch
/mnt/sdb1/scratch2
/mnt/sdc1/scratch
/mnt/sdc1/scratch2
/mnt/sdd1/scratch
/mnt/sdd1/scratch2
Changing these to;
/mnt/sdb1/scratch
/mnt/sdb1/scratch
/mnt/sdc1/scratch
/mnt/sdc1/scratch
/mnt/sdd1/scratch
/mnt/sdd1/scratch
made no difference - the results are pretty close to just having the 3 straight entries, one per scratch drive. Guess my bottleneck is somewhere else. Either way, I'm pretty happy with
Swap transfer rate ..... 3125.498 MiB/s
Total performance ......  5099
CPU performance ........  4355
Swap performance ....... 17311
Cheers -
Offline mcgillca
    • Astrobin Website
« Reply #10 on: 2014 November 17 13:39:38 »
Hi - I have 2 SSDs. I tried having multiple swaps reference the same disk (under Windows 7), and saw some improvement (say 50%), but got the swap speed to trebble when I had half the entries referring to one SSD, the other half to the other disk.
I also realised that when I upgraded my BIOS, the overclocking parameters got wiped, so reinstated these and overall, my benchmark increased significantly (3 times swap, extra 15% for the overclocking).
Thanks, Juan - a real improvement for just a few minutes work (for me anyway - I'm sure this took you days to code!).
Colin
Paramount MX
Ikharos 8" Carbon Truss RC
Atik 460ex
Atik EFW2 with Baader LRGB and HA SII OIII
ONAG with Atik 314L+
http://www.astrobin.com/users/mcgillca/
Offline jkmorse
« Reply #11 on: 2014 November 19 14:26:56 »
For those of us who are not hardware experts, does it make any sense to add an SSD drive externally and not through a motherboard connection?  Use a laptop for PI and want to see if I can get a significant speed boost by adding an external SSD drive.  If it is worthwhile, what is the minimum size SSD drive that I should consider adding?
Jim
Apogee Aspen 16803
Offline NGC7789
« Reply #12 on: 2014 November 19 14:40:45 »
That would depend on the interface of the external drive and how it compares to the internal connection. If it's USB3.0 or eSata and you are comparing to an internal hard drive (especially a 5400 rpm one typical for a laptop) then there would be a benefit. Keep in mind that these interfaces top out at about 300 MB/sec so you don't need to spend money on a top SSD that can go at 500MB/sec or better. Also make sure you pay attention to both read and write speeds too.
Offline jkmorse
« Reply #13 on: 2014 November 19 17:11:41 »
Thanks, have 2 3.0 USB ports so will give it a try.
Jim
Apogee Aspen 16803
Offline jkmorse
« Reply #14 on: 2014 November 22 21:01:06 »
Thought I would report on effects of subbing out an HDD with an SSD, then adding swap files.  First, using the HDD in basic mode, here were my results:
Total 1672; CPU 4796; Swap 454; MiB/s: 81.885 (pathetic)
Replacing the HDD with the SSD resulted in the following:
Total 4645: CPU 4654; Swap 4617; MiB/s: 833.663 (an amazing tenfold improvement!!  :))
Finally, first try at adding swap directories (simply created a 128GB partition, created a "swap" folder, then pointed to that folder 4 times in the Swap Storage Directories; welcome suggestions on how to do that more efficiently so I get more bang for the buck):
Total 5081; CPU 5038; Swap 5276; MiB/s: 952.628 (more improvement and will surely go higher with some trial and error  :D)
For reference, this is from a Samsung NP880z5e Laptop  with a Core i7 and 16GB of ram.  The SSD is a Samsung 840 EVO 1TB.
The speed increase is magical and I can't wait to put all that speed to use in my image processing.
Thanks Juan!!
Jim
Apogee Aspen 16803
