Author Topic: Can't get Luminance mask in ACDNR working right in 1.2  (Read 3868 times)
well I bought a license so it's open season now :) I'm hoping someone can tell me what I'm doing wrong here. I'm trying to reduce noise in my image. To keep the bright areas protected I use a luminance mask. It seems the mask prevents any noise reduction to take place, not just in the black areas. So clearly I didn't quite understand how this works :)
Here's a screen shot of the mask:
http://gallery.tungstentech.com/main.php?g2_itemId=767
Here's a screen shot of the preview with mask enabled:
http://gallery.tungstentech.com/main.php?g2_itemId=773
Notice the lack of noise reduction.
Here's the mask disabled:
http://gallery.tungstentech.com/main.php?g2_itemId=770
Notice noise reduction in full effect.
I've created an image of the preview I used and uploaded it here:
http://cid-a93625fef5ca95fb.skydrive.live.com/self.aspx/PixInsight/SmallSection.7z
Thanks for any tips you can provide,
« Reply #1 on: 2008 July 23 03:50:25 »
Hi Sander,
Now I have a new user, a terrific bug hunter, and a C++/JS developer, all in a single operation, so what else can I ask for? :) Thank you for your support, and welcome aboard.
There's nothing wrong in the way you're using ACDNR. It's just that you have defined a mask that is too restrictive. I have reproduced your parameters and I get just the same poor noise reduction.
Try with a more permissive mask; for example:
http://forum-images.pixinsight.com/legacy/acdnr-sander/01.jpg
which gives you a reasonable noise reduction:
http://forum-images.pixinsight.com/legacy/acdnr-sander/02.jpg
However, for this image you actually don't need a mask:
http://forum-images.pixinsight.com/legacy/acdnr-sander/03.jpg
As you see, ACDNR performs very well without the help of a mask for images like this one. A mask is required when there are more differences between high-SNR and low-SNR regions; for example, when there are subtle variations over bright areas with little noise. It's a matter of practice.
Note that I've used edge protection overdrive parameters on both sides. This has helped in protecting star profiles. I've used overdrive also in the chrominance, to protect small stars from becoming grayed out:
http://forum-images.pixinsight.com/legacy/acdnr-sander/04.jpg
The overdrive parameters exaggerate edge protection. With overdrive=0, the algorithm tries to achieve the same contrast as in the original image for protected edges. When overdrive > 0, contrast is increased for protected edges, which has a sort of sharpening effect. Overdrive can help, but these parameters must be used with great care. If in doubt, better don't use them.
Hope this helps.
