Author Topic: Best time in processing to use SCNR  (Read 3893 times)
Offline javajunkie2121
« on: 2014 October 11 12:09:09 »
Hi:
when is the optimal time to use SCNR..linear stage?  nonlinear?
I know I should be after color calibration...but I've seen mention of issues with SCNR if you've applied a lot of smoothing to the image..so if I'm using noise reduction (ATWT/MMT in linear, TGVDeNoise in nonlinear)..should SCNR precede these steps?
jeff
Offline Josh Lake
Re: Best time in processing to use SCNR
« Reply #1 on: 2014 October 11 16:18:30 »
I always use it after going non-linear, often after employing the LRGB Combination 'trick' that Vicent highlights in this video. I would keep the full amount of each channel (including green) until you hit the 'artistic' part of processing when non-linear.
« Reply #2 on: 2014 October 12 10:42:49 »
thanks for the reply Josh.
so if I'm processing a OSC RGB image, SCNR ought to come after color saturation (using curves transformation) tweaking?
jeff
Offline Josh Lake
« Reply #3 on: 2014 October 16 09:47:21 »
I think that would be best, yes. I haven't heard that any other time is better!  :)
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« Reply #4 on: 2014 October 16 18:37:10 »
Only time I use in the linear phase is when processing narrowband images in the Hubble palette.  For RGBs I use after stretching.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
« Reply #5 on: 2014 October 16 18:55:37 »
Jeff,
I rarely use it before stretching. Most of the times that only causes issues. After so many hours of processing I now tend to not use it until the end of my processing.
