Author Topic: Using a masterdark in BPP script  (Read 3151 times)
Offline cdavid
    • Through Space and Time
« on: 2014 October 03 04:34:39 »
Hi...I have various master darks in my library which I previously created the old manual way  (integration after master bias calibration). I also used to make a version without master bias calibration.
So in the BPP script which should I use....does the script detect master darks that have been bias calibrated or will it subtract the bias again?
Thanks!
Carlos
Offline cdavid
Re: Using a masterdark in BPP script
« Reply #1 on: 2014 October 07 11:37:04 »
Anyone know? Thanks
Offline Ignacio
    • PampaSkies
« Reply #2 on: 2014 October 07 12:12:51 »
I don't think it does. I only use BBP for bayer drizzle processing, and since I typically work with uncalibrated master darks with my DSLR cameras (to avoid data truncation), I subtract the master bias prior to feeding it to BPP.
Ignacio
Offline cdavid
« Reply #3 on: 2014 October 07 18:54:45 »
Thanks Ignacio....so you mean that you calibrate your master dark using the calibrate process prior to BPP?
Do you also give BPP a master bias to calibrate flat and lights?
« Reply #4 on: 2014 October 07 19:36:58 »
Hi Carlos, this video can help.
Saludos, Alejandro.
Offline cdavid
« Reply #5 on: 2014 October 08 04:31:24 »
Thanks Alejandro! Perfect just what I needed to know. I've been using bias calibrated master darks  in the BPP which explains some errors and artifacts I've been seeing.
Cheers!
Carlos
