Author Topic: PCL Win32 exception  (Read 3027 times)
Offline astroman2
PCL Win32 exception
« on: 2014 September 07 05:21:06 »
Usually get this error when dragging blue triangle at base of a panel.  When it occurs several icons get dragged by the mouse-refer attached document with red arrows showing details.  When releasing the mouse the exception error pops up.  This may be coincident with limited memory.
Regards
Astroman
Re: PCL Win32 exception
« Reply #1 on: 2014 September 11 04:14:46 »
I can't reproduce this problem, and nothing similar has been reported so far. Can you provide more information on your machine, operating system, etc? Thanks!
Offline sixburg
« Reply #2 on: 2014 December 11 07:36:11 »
I can confirm the very same error.  It started about 10 days ago.  My machine is a Dell XPS15 laptop, 16gb RAM, Win8, etc.  PI version is 1.08.03.1123.  This started before I downloaded the latest.
To reproduce the error try to select a bunch of image or process icons.  Then selected align left, for example.  Drag those icons off to the right hand side of the screen.  Somewhere during this the icons will be duplicated and start to behavior erratically.  Even now, of the my image icons is"persistent" and showing up on this screen as I type this message.
The second attachment shows a bunch of iconized images on the right center of the screen.  Prior to the error message that same group of icons was mirror imaged or "ghosted" on the other side of the screen.  Once the icons are dropped, the error message appears.
