Author Topic: mosaic  (Read 2436 times)
Offline blackdragon72
mosaic
« on: 2014 September 02 22:13:11 »
In my typical flow, I do crop, DBE, back ground neutralization and color calibration, TGV, Deconv, then HT stretch. If I need to do mosaic, what is the best time to combine images?
Offline JoLo
Re: mosaic
« Reply #1 on: 2014 September 03 14:04:18 »
For my mosaics, I try to do them both ways and see which looks better.  For method 1, i combine them early in the workflow then do the processing steps on the combined image.  This will work fairly well if the two were reasonably close in brightness, contrast and noise levels to start with.  You may want to add Linear Fit to your mosaic workflow, it will help equalize the background levels.
Some mosaics I find that processing them separately works well and then combining them toward the end.  For either method, a bit of tweaking may be required after combining.  Once you go non-linear, keeping the brightness / contrast in equilibrium becomes more of a challenge.
Orion Atlas
AT106
AT65
Canon 450D
Atik 314L+
Orion 12" Dob
