www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
Bug Reports
PI chrash - CatalogStarGenerator - STF
« previous
next »
Print
Pages: [
1
Author
Topic: PI chrash - CatalogStarGenerator - STF (Read 3082 times)
Herbert_W
PixInsight Addict
on:
2014 September 01 03:55:18 »
Hi Juan,
PI chrashes, when using STF to an image created with CatalogStarGenerator.
I've tried it several times - always the same.
win7 64bit
PI 01.08.02.1098
Best regards,
Herbert, Austria
Logged
PTeam Member
PixInsight Jedi Grand Master
Re: PI chrash - CatalogStarGenerator - STF
Reply #1 on:
2014 September 11 04:29:34 »
Hi Herbert,
I can't reproduce this problem with CatalogStarGenerator version 2.0.2. Which version are you using, and what parameter values are you setting on the script? Can you provide a process icon with an instance that causes this problem?
Logged
Herbert_W
PixInsight Addict
Reply #2 on:
2014 September 12 12:21:36 »
Hi Juan,
Here is the xpsm
http://endor.uv.es/files/data/public/3eed32.php?lang=de
Here is a screenshot with the settings
http://endor.uv.es/files/data/public/11a5f5.php?lang=de
With >Automatic Apperance< is checked, I cant produce a crash :-)
But with >Automatic Apperance< unchecked and some certain settings ... :-(
Thank you for your help and best regards.
Herbert, Austria
Logged
Andres.Pozo
PTeam Member
PixInsight Padawan
Reply #3 on:
2014 September 13 03:52:22 »
I can not reproduce the crash with the parameters that you have posted.
In any case, those parameters are not very usefull. You are using a background magnitude of -1.5. This will swamp all the stars with a greater magnitude than that. It is like trying to do astrophotography in daylight.
Another important thing to know: The autostretch of STF stretches the image by a factor that depends on the stdDev of the image that also depends on the noise of the image. Because of this, the autostretch usually over-stretches the images generated by CSG with the option "Generate noise" deactivated.
Logged
Gallery @ Astrobin
georg.viehoever
PTeam Member
PixInsight Jedi Master
Reply #4 on:
2014 September 13 11:12:32 »
I also cannot reproduce the crash on my Windows 7 system, based on the settings in the screenshot. The zip file appears to be empty.
Logged
Print
Pages: [
1
« previous
next »
PixInsight
Bug Reports
