Author Topic: Can't remove the glow around an open cluster...  (Read 3197 times)
Offline Gardner Gerry
    • http://gdgerry.zenfolio.com/
« on: 2014 August 29 10:14:20 »
Hi all,
This is an image of M52, shot with a TV101 and QHY9C. 22 x 300 sec subs, calibrated with bias and darks in PI 1.8. I did use my 2" IDAS LP filter as I'm in the suburbs near a bright city, but I can see Milky Way on good transparent nights, which was the case the night I captured this data.
I'm trying to remove the glow about the cluster. It does not seem to be there on images I find of M52 on the web, so I'm assuming it doesn't belong. ABE or DBE do not seem able to remove this. I'm stumped. Ideas anyone?
~ Gardner
Re: Can't remove the glow around an open cluster...
« Reply #1 on: 2014 August 29 10:47:52 »
Hi Gardner,
Maybe you can upload your integration and someone can make a try. In the .jpg is difficult to see the problem.
Saludos, Alejandro.
~ Gardner
« Reply #3 on: 2014 August 29 13:20:55 »
Hi Gardner,
Sorry that I did not express correctly. What would be needed is the Integration without further processing to apply DBE or ABE to the linear image. If you used BPP is the image called light_BINNING_1.fit
Saludos, Alejandro.
Offline sreilly
« Reply #4 on: 2014 August 29 13:29:09 »
Not sure what affect the LP filter would have on a normal night. Personally I don't see this glow but then I also think the image is rather dark to start with. It would help to know what has been done to the image and in what order.
-Steve
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
« Reply #5 on: 2014 August 29 14:14:54 »
Alejandro.
Here is the file after calibration and stacking, no further processing applied.
https://www.dropbox.com/s/4ky7sd5w6a1du6x/light-FILTER_Filter_1-BINNING_1.fit?dl=0
Thanks for taking a look at this.
~ Gardner
« Reply #6 on: 2014 August 29 15:41:03 »
Hi Gardner
Try this DBE process in your light_BINNING_1.fit image.
Saludos, Alejandro.
