Author Topic: IC 410 NB : HA S2 O3  (Read 2502 times)
Offline Robovet
    • robovet.net
« on: 2014 August 19 20:32:00 »
This image was calibrated with the batch script. I wasn't sure it would succeed since some of the images were different rotation angles due to meridian flips, and hence so were the flats. I guess PI figures that out. I used pixel math R= .5HA+.5S2 G=0.15HA+0.85O3 B=O3 for the RGB combo. I had to experiment with color calibration and finally used the whole image for white reference with structure detection unchecked. Curves transformation to fine tune the saturation. A lot of the workflow was from the Light Vortex example.
Edge HD 11 with .7 reducer; Apogee U16 Astrodon 5nm HA 3nmO3 & 5nm S2; no RGB stars as of yet. 30 minute subs (16 each)
https://www.flickr.com/photos/94597165@N00/14976031225/in/photostream/lightbox/
marc
Dr. Marc Laxineta
Equine Veterinary Medicine
Event Photography
www.robovet.net
951-378-1134  Cell
Offline Dimitris Platis
Re: IC 410 NB : HA S2 O3
« Reply #1 on: 2014 August 20 00:53:50 »
Oh...that is so fantastic..
I would certainly beg for some more info on your workflow.....and should u decide to share this data..I think grateful would be an understatement.
I love the way u handled the little color nuances and variations and if I may suggest...u have such good data that removing noise reduction might even improve the image aesthetically.
Offline Geoff
« Reply #2 on: 2014 August 20 02:18:55 »
Exquisite detail and colour Marc.
Geoff
Don't panic! (Douglas Adams)
Offline Robovet
    • robovet.net
« Reply #3 on: 2014 August 20 06:30:20 »
Hi Dimitris
Most of the workflow can be found here:    http://lightvortexastronomy.blogspot.com/2013/02/tutorial-nebulae-pixinsight-workflow.html
I experimented a lot with his steps.
Dr. Marc Laxineta
Event Photography
www.robovet.net
951-378-1134  Cell
Offline dayers
    • The Orlop
« Reply #4 on: 2014 August 20 08:22:54 »
This image really speaks to me. Beautiful! Thanks for sharing it with us.
Dave
Dave Ayers
  Stellarvue 80 mm refractor on CG-5 mount, Orion 50mm guide scope. Imaging camera SBIG STF-8300M, guide camera ASI120mm. PHD Guiding. Sequence Generator Pro, PixInsight.
