Author Topic: Sh2-86 in Colour  (Read 2161 times)
Offline Astrodoc
    • AstroDoc - Astrophotography by Ron Brecher
Sh2-86 in Colour
« on: 2014 August 11 10:37:33 »
This image uses the 8 hr of Ha data posted yesterday along with 5.5 hr RGB data collected a few weeks ago.  All pre-processing and processing in PixInsight.
http://astrodoc.ca/sh2-86-emission-nebula-colour/
Thanks for looking, and I hope you enjoy it!
Clear skies,
Ron
Clear skies,
Ron
Offline Jason Tackett
    • Astrobin Page
Re: Sh2-86 in Colour
« Reply #1 on: 2014 August 13 06:37:40 »
Very nice work! I like how your processing steps are not very aggresive and yield such good contrast in the nebulosity. The yellow stars also stand out well. I see you used ACDNR twice - once targeting small scales before HT and again after HT targeting large scales in the background. Did you use the standard deviation in the ACDNR process to target these scales or some other setting? This seems like a good idea. I was just curious about the rationale. Thanks for sharing!
Jason
Offline Astrodoc
« Reply #2 on: 2014 August 13 06:46:57 »
I use the standard deviation slider to adjust scale.  First I use small scale NR (around 0.8-1.2 px scale) with a very light mask for luminance to provide overall noise reduction to the image (chrominance around 1-1.6 px scale; no mask).  Then, after resetting the black point, I apply noise reduction with a larger scale (4-6 px luminance; 5-7 chrominance) and use quite a dark mask (on both luminance and chrominance) to limit this step to the lowest signal regions of the image.
Clear skies,
Ron
« Last Edit: 2014 August 13 07:11:33 by rbrecher@rogers.com »
Clear skies,
Ron
    • Astrobin Page
« Reply #3 on: 2014 August 13 09:37:14 »
Thanks for the details. That seems like an effective procedure to lower noise globally and then aggressively in the background.
