Author Topic: Building mosaic - getting panels to same levels  (Read 4226 times)
Offline cmassa
« on: 2014 August 08 09:33:11 »
I'm having trouble building a 4 panel mosaic of the Veil Nebula because the background lightness varies between the panels. When put together with gradientmergemosaic, the panel differences still show. What is a good way to balance the panels so they are even? I am assembling the mosaic after cropping, ABE or DBE, background neutralization, color calibration and before doing any stretching. Images are shot with a Baader IR  modified Canon T2i.
Thanks for any advice.
Chris
iOptron CEM60, Celestron Advanced VX mounts
Celestron 8" EdgeHD SCT, Astrotech AT65EDQ
Atik 383L+ mono, EFW2 Filter wheel, Baader filters,Canon T2i/550D, self modded with Baader IR
Astrotech 50mm guides scope
ZWO ASI120MC - guiding and planetary imager
My images: http://www.astrobin.com/users/cmassa
Re: Building mosaic - getting panels to same levels
« Reply #1 on: 2014 August 08 09:49:05 »
i usually just define previews over areas of background and check the mean values, then scale one of them by the ratio of the means. seems to work ok.
Offline cmassa
« Reply #2 on: 2014 August 08 09:52:19 »
Hmm,
That does make sense, I just don't know how to do that. What process is used?
Chris
« Reply #3 on: 2014 August 08 11:59:30 »
first - the images should still be in linear form
so i just make previews on each image, then use the Statistics process to look at each preview in turn. then using pixel math, i apply the following expression to the one with the dimmer background:
$T*(mean_brighter/mean_dimmer)
that should scale the dimmer one it by some value > 1.
in fact you could probably come up with a pixel math expression that just directly calculated the mean values of the previews, probably with Mean(brighter->preview1) or Median(brighter->preview1) etc. need to try this to verify that it works.
Offline mads0100
« Reply #4 on: 2014 August 10 12:37:44 »
One thing I found when my mosaic was doing this was that I had a small 1-2 pixel black line down where it was trying to merge the mosaic.  It was playing havoc with GradientMergeMosaic's process and really messed it up.  I didn't notice it until I really zoomed in.
« Reply #5 on: 2014 August 10 18:45:08 »
that's a good point - any strong discontinuities (like a bright star, or a black border) can mess up GMM's gradient computation…
Offline cmassa
« Reply #6 on: 2014 August 10 21:13:18 »
I image at 20-25% overlap and make sure to crop the borders.
Chris
« Reply #7 on: 2014 August 11 05:59:14 »
If you share images, I can have a look.
Generally, GMM will not get rid of differences in texture (such as noise "patterns") or differences in scale (contrast). The corrections GMM does are purely additive. To arrive at a similar scale, try LinearFit.
Offline cmassa
« Reply #8 on: 2014 August 11 06:42:28 »
That's what I am having trouble with is differences in contrast. I tried to use the linearfit tool but can't seem to figure it out. The one time I got it to work, one image came out black, no data left. I've searched online and can't seem to find how to use it and there is no documentation in PI.
Chris
Offline cmassa
« Reply #10 on: 2014 August 11 07:05:37 »
Thanks. The example there uses two single frames. Will this also work with stacked images? If so, should this be done right after stacking? Or should some background extraction be done first. I tried using images that were slightly different size (cropped to remove stacking artifacts) but it gave me errors regarding geometry differences and stopped.
Chris
« Reply #11 on: 2014 August 11 07:14:13 »
The images for LinearFit (and GMM) need to be aligned to each other (and thus have identical dimensions). I usually do it (LinearFit and GMM) after stack+DBE, before any non-linear operation. But I know that others have gone different paths.
