Author Topic: Processing speed  (Read 2856 times)
Offline Dimitris Platis
Processing speed
« on: 2014 August 05 09:11:50 »
I have an i7 8core, 16GB RAM PC and it usually takes me 2mins to make a star mask.
How long does it take u people? R there any adjustments that I am missing that can improve my speed?
Offline sreilly
Re: Processing speed
« Reply #1 on: 2014 August 05 09:26:08 »
Dimitris,
Just taking a guess here on my images, using a 12.5" RC and STL-11002, maybe 20-30 seconds at best but let me qualify that I suspect if you use a wide field setup with a huge amount of stars it would take a lot longer.
-Steve
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
« Reply #2 on: 2014 August 05 09:27:50 »
I am using an RC8'' with a reducer at 1150mm
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« Reply #3 on: 2014 August 05 14:45:43 »
Dimitris,
Based on my experience, your time is not all that unusual.  I have two rigs, one similar to Steve's and I see times similar to his, and one where I shoot wide fields (and use drizzle) that can take considerably longer, sometimes even more than the 2 minutes you are seeing.  Lots of computing going on in generating those masks.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
« Reply #4 on: 2014 August 07 14:02:21 »
Run the PixInsight benchmark http://pixinsight.com/benchmark/ . The compute part should give you an idea about the performance of your system.
Offline Jason Tackett
    • Astrobin Page
« Reply #5 on: 2014 August 07 15:56:58 »
One way to help dial in the StarMask settings faster is to make a small preview which contains all of the star sizes you are after and then make that preview a separate isolated image by dragging the preview tab away from the parent image. For some reason I've found that StarMask runs faster on the smaller preview image by itself rather than when StarMask is applied to a preview that is docked with the main image.
Jason
