Author Topic: NGC6302--Butterfly (aka Bug) Nebula  (Read 2928 times)
Offline Geoff
« on: 2014 August 03 18:15:51 »
http://www.astrobin.com/104993/C/
The core of this object was surprisingly bright at 10 min subframes.  Reduction to 200 second subframes resolved this issue. Two separate images were processed and then combined with HDRComposition. Processing was quite standard for both images:
  • ChannelCombination to produce a linear RGB image, followed by DBE and ColorCalibration.
  • DBE and deconvolution on the luminance
  • Combine L and RGB to produce a linear LRGB image
  • Masked stretch
  • HDRComposition
  • Play around with Curves (for saturation), Histogram, TVG denoise
  • Apply HDRMultiscaleTransform to the composite image with stars protected by a mask (thanks to Cosmick for suggesting this)
  • Minor cosmetic changes
Geoff
Don't panic! (Douglas Adams)
Offline vicent_peris
    • http://www.astrofoto.es/
Re: NGC6302--Butterfly (aka Bug) Nebula
« Reply #1 on: 2014 August 04 02:21:40 »
Hi Geoff,
Nice image. HDRC was designed to work with linear images, not with processed ones. As you say, you first processed the images. Could I see them separately? Maybe the stars are not very good (see that all of them have a kind of "separate cores") due to this workflow.
Vicent.
Offline lucchett
« Reply #2 on: 2014 August 04 15:06:59 »
Hi Geoff,
Could you also detail how do you build a linear LRGB?
Are you using the LRGB combine tool?
Thanks, andrea
Offline Geoff
« Reply #3 on: 2014 August 04 18:14:33 »
Hi Geoff,
Vicent.
Thanks Vicent.  The files have been uploaded to Endor:
1. Linear_200sec subs
http://endor.uv.es/files/data/public/165c44.php
2. Linear_600sec subs
http://endor.uv.es/files/data/public/a62251.php
3. RGB_200sec subs
http://endor.uv.es/files/data/public/138b8b.php
4. RGB_600sec subs
http://endor.uv.es/files/data/public/4c67a5.php
The only processes applied have been image calibration and registration.  Each luminance has been registered to its corresponding RGB image, but the short exposures have not been registered to the long exposures.
Regards
Geoff
Offline Geoff
« Reply #4 on: 2014 August 04 18:55:50 »
Hi Geoff,
Thanks, andrea
Hi Andrea
  • First combine the RGB images using the ChannelCombination tool with the radio button RGB checked
  • Then open the ChannelExtraction process and check the CIE L*a*b* radio button.  Apply to the RGB image generated in step1. This will generate a luminance image (which you will discard) and two images for colour.
  • Go back to the ChannelCombination tool and click the CIE L*a*b* button.  Use the _a and _b colour images from step 2, but replace the discarded luminance generated in step 2 by your luminance.  Hit the apply button and you will generate the linear LRGB image.
Regards
Geoff
