Author Topic: File size limit?  (Read 4375 times)
Offline cmassa
File size limit?
« on: 2014 July 29 13:17:10 »
I have been working on a 4 panel mosaic and am playing with drizzle integration. I have run the panels which were stacked with 2x drizzle. I used star alignment to create the mosaic and register the parts to be used with gradientmergemosaic. The files are about 2.5 GB in size, with the mosaic being about 18,000 pixels in the long dimension.
When I try to open the mosaic created by star alignment or open the registered files I get an error message stating (sorry, can't figure out how to post an image here)
PCL FITS Format Support: Unable to open FITS file: mosaic.fit
CFITSIO error mesage stack:
01: failed get the size of the following file: (ffopen) mosaic.fit
I shortened the file name to mosaic.fit for less typing.
The PC is running Windows 7 Professional and has 8GB of RAM.
Is there a limit to the file size which can be opened in PI?
Chris
iOptron CEM60, Celestron Advanced VX mounts
Celestron 8" EdgeHD SCT, Astrotech AT65EDQ
Atik 383L+ mono, EFW2 Filter wheel, Baader filters,Canon T2i/550D, self modded with Baader IR
Astrotech 50mm guides scope
ZWO ASI120MC - guiding and planetary imager
My images: http://www.astrobin.com/users/cmassa
Offline cmassa
Re: File size limit?
« Reply #1 on: 2014 July 29 13:18:08 »
Well, I guess it did upload the image.
Offline Andres.Pozo
« Reply #2 on: 2014 July 30 02:27:44 »
I found this same problem last year and I reported it in this message:
http://pixinsight.com/forum/index.php?topic=6469
Offline cmassa
« Reply #3 on: 2014 July 30 06:33:49 »
PI saved the file just fine, now it just won't open it.
This would not allow the use of drizzle integration to make mosaics then because the files sizes get big very quickly.
CHris
« Reply #4 on: 2014 July 30 11:22:50 »
This is a specific problem with CFITSIO on Windows. On FreeBSD, Linux and Mac OS X there are no practical file size limits. As an example on the Linux laptop where I'm writing this, I have just written a FITS image with 24000x24000 pixels and three channels in 32-bit floating point format. Then I've closed the image and reloaded the disk FITS file without problems. Note that this image is about 6.5 GB.
CFITSIO is a rather old software library. It has never been designed to be truly portable code in my opinion. I have never liked it for many reasons, but it is the "gold standard" for FITS format support and our FITS support module depends on it since the g'old times of PixInsight LE. The current FITS module uses CFITSIO version 3.35 (June 2013). I'll update it to version 3.37 (June 2014) on September, but I doubt this will fix this problem on Windows.
Ideally, it's time to forget CFITSIO and use something more contemporary. Implementing a FITS support library from scratch is not a realistic option in the short-middle term, so if anyone knows a better FITS support library in C, I am extremely interested in hearing his or her opinions.
Anyway, I'll try to dive into the black waters of CFITSIO code to see if I can hack it to solve this problem. On a parallel note, I strongly recommend using Linux or FreeBSD (and even Mac OS X) for complex and demanding tasks such as building these huge mosaics.
Offline cmassa
« Reply #5 on: 2014 July 30 13:37:13 »
Thanks for the explanation. Guess I'll try installing a dual boot of Linux with Windows 7.
Chris
Offline cmassa
« Reply #6 on: 2014 August 01 17:54:43 »
I have installed Ubuntu and have PI running. When I try to open the registered/aligned files of my mosaic I get a similar message to one I got in Windows:
GradientMergeMosaic: Global context
Start: Gradient Domain Merge Mosaic
Start: Loading images
Start: Loading image /home/chris/PI  Images/Registered/Panel 1 _drizzle_integration_ABE_CC_r.fit 0
Reading FITS: 32-bit floating point, 3 channel(s), 18097x11951 pixels: done
*** PCL Exception: PCL FITS Format Support: FITS file read error:
CFITSIO error message stack:
01 : Error reading data buffer from file:
02 : /home/chris/PI  Images/Registered/Panel 1 _drizzle_integration_ABE_CC_r.fit
03 : Error reading elements 14401 thru 18097 from image (ffgcld).
Stop: Loading image /home/chris/PI  Images/Registered/Panel 1 _drizzle_integration_ABE_CC_r.fit 0. Time used:  0:13:44.820
Stop: Loading images. Time used:  0:13:44.902
Stop: Gradient Domain Merge Mosaic. Time used:  0:13:44.924
Any ideas?
Chris
« Reply #7 on: 2014 August 02 01:17:32 »
Really not the same error. This time CFITSIO is telling you that it cannot read the final part of the image. So the file generated on Windows is not valid (even if CFITSIO gave no error upon writing it). I'm afraid you'll have to generate the whole mosaic again on Linux...
Offline cmassa
« Reply #8 on: 2014 August 02 06:38:11 »
Thanks. I have gotten more exposures so I need to redo it anyway.
One other question about Linux, when I want to open files in PI while in Ubuntu it can only see the drive where Ubuntu is installed. I cannot navigate to my storage drive where the images are. But the file navigator in Ubuntu shows all of the drives. I can drag files into the PI window to open them but I don't know that it will work to load a script. How do I get PI to see and navigate to all of the hard drives on the system? Windows and Ubuntu are installed on different drives in a dual boot configuration.
Chris
Offline NGC7789
« Reply #9 on: 2014 August 02 06:54:23 »
In the Open dialog choose "Computer" and navigate to the mount point of your storage drive. In my case my storage drive is at /media/<user name>. I'm not sure how to get it to appear in the sidebar.
-Josh
Offline cmassa
« Reply #10 on: 2014 August 02 07:20:35 »
There they are, thanks. Seems like a strange place for them to be but I really don't know or understand Linux yet.
Chris
Offline bhwolf
« Reply #11 on: 2014 August 02 10:48:22 »
Does the latest CFITSIO solve this issue?  In looking very briefly at the release notes:
http://heasarc.gsfc.nasa.gov/FTP/software/fitsio/c/docs/changes.txt
... there are a couple of references to handling large files but not sure if it would solve this problem.
Offline NGC7789
« Reply #12 on: 2014 August 02 16:44:29 »
It turns out you can just drag and drop items from the right side of the Open dialog to the left side (what I called the sidebar). Then they are easily accessible on subsequent dialogs.
P.S. Sorry for the thread hijack :)
Offline cmassa
« Reply #13 on: 2014 August 02 17:09:39 »
Thanks for the info!
Chris
