Author Topic: Atik 314l+ Debayering  (Read 3862 times)
Offline RockHound
« on: 2014 July 28 17:58:21 »
Hi All
I am trying to process some images of m16 but i have forgotten the bayer patten. I have tried all 4 wach with very different results  ???. I have tried searching but can't seem to get an answer, so does anyone know which one it is?
Cheers
Paul
Re: Atik 314l+ Debayering
« Reply #1 on: 2014 July 28 19:37:50 »
try changing your fits reader direction, that may help.
Offline bhwolf
« Reply #2 on: 2014 July 28 21:26:19 »
Take an image inside, doesn't have to have a lens or be in focus, maybe hold it up to your computer screen with green or other color.  Or hook it up to your finder and take an image of anything even if it's only marginally in focus.  You can then try the settings to see which looks right.
Offline RoStm
« Reply #3 on: 2014 July 29 00:27:40 »
AFAIK the Atik 314 L+ is a s/w camera. So what should Debayering bring out here?
Rolf Stadelmaier
Edit: I should have written monochrome instead of s/w (black/white).
« Last Edit: 2014 July 29 00:45:46 by RoStm »
Offline JoLo
« Reply #4 on: 2014 July 29 08:16:40 »
Yeah, as far as I know the 314 is a monochrome camera, so Debayering is not in the mix.  Did you take images through RGB filters?
Orion Atlas
AT106
AT65
Canon 450D
Atik 314L+
Orion 12" Dob
« Reply #5 on: 2014 July 29 08:33:43 »
ha, didn't realize it was a mono camera :)
Offline javajunkie2121
« Reply #6 on: 2014 July 29 17:39:14 »
atik 314L+ is available as OSC as well as mono..I have the OSC version..likely OP has the same
Offline RoStm
« Reply #7 on: 2014 July 30 00:38:11 »
Yes,
but this one is named 314 C+
Rolf
« Reply #8 on: 2014 August 02 13:13:47 »
maybe in Europe?  in US atik OSC is called 314L+, not C...I own the atik 314L+ OSC ...
