Author Topic: NGC2264  (Read 2566 times)
Offline lucchett
NGC2264
« on: 2014 July 27 14:18:18 »
Hello,
this is my last attempt.
http://andrealucchetti.smugmug.com/Astrophotography/Portfolio/i-cq3Psc9/0/X3/IM_2-X3.jpg
the web image is more "loaded" that what I see in my PC.
The Image was acquired from Tuscany during winter/spring 2014.
It is an experiment to understand what can be done mixing 1x1 Ha data and 2x2 RGB data.
Fully processed in Pixinsight.
TEC140
Moravian G16803
Andrea
Offline Lex
  • We do it at night...
Re: NGC2264
« Reply #1 on: 2014 July 27 15:56:55 »
Hi Andrea,
wow there's a lot of detail in your image! Well done! What are the exposure details?
Best
Clear Skies!!
Lex
Offline lucchett
Re: NGC2264
« Reply #2 on: 2014 July 28 01:04:54 »
Thank you Lex!
Ha: 15x1200s
RGB: 12*600s each channel
Due to a robofocus issue, FWHM is a bit higher for the Ha.
May be this helped the Ha blend with the RGB :-)
I had several issues in eliminating the gradients and doing the blend.
Andrea
« Last Edit: 2014 August 03 12:00:34 by lucchett »
