Author Topic: Ha Detail without Killing Reflection Nebulosity?  (Read 3801 times)
Offline Terry Danks
« on: 2014 July 24 11:37:02 »
I am presently working on M20, The Trifid from my disadvantageously far north location. At a maximum 21degrees altitude, I will never achieve award-winning quality but the subs do look nice enough to continue.
I have noticed remarkable detail in the Ha on this object. Of course the reflection stuff hardly appears at all in Ha though.
What is suggested as coming to the best possible compromise here in maintaining Ha detail while still doing justice to the blue reflection nebulosity?
Offline Warhen
    • Billions and Billions
Re: Ha Detail without Killing Reflection Nebulosity?
« Reply #1 on: 2014 July 25 11:32:35 »
Terry, there are several ways to do it. I'll be detailing them in tutorial chapters already written but in need of production. I like the NBRGB script. Try mixing in the Ha with RGB image there. Also try the HaRGB-AIP script. Sometimes the 'RHA_RVB' image is very useful alone or added back with the original image.
My personal preference is never to 'make reds redder' w/ Ha, thereby cancelling out the nice natural variegation of pinks, etc. Rather as you say, use that detail! And that's often best applied to L. I've had good success with this-
1. Apply HDRMultiscaleTransform to the Ha when appropriate to compress its wide dynamic range.
2. With PixelMath, add 20% of the Luminance (or extracted L*) to 80% of the Ha, thereby adding the L's star contribution to the finer detailed Hydrogen alpha image.
3. Replace the (L)RGB's Lightness channel with that new Ha + L composite using ChannelCombination in Lab mode.
You can also add masks if the Ha negatively impacts other non Ha regions.
Best always, Warren
Warren A. Keller
www.ip4ap.com
Offline Terry Danks
« Reply #2 on: 2014 July 25 17:48:19 »
Many thanks, Warren. I'll be looking for the tutorials when they become available.
In the meantime, I'll concentrate on getting data!
Terry
Offline vicent_peris
    • http://www.astrofoto.es/
« Reply #3 on: 2014 July 26 05:11:35 »
Hi Terry,
In images where there is an important contribution to the nebula from other wavelengths, I always put the H-alpha data in the lightness of the color image. This is done to preserve all the color information.
The main problem we face by putting the H-alpha image as lightness of the color image is that the nebulae are much brighter in the ew lightness than in the original one. This causes a loss of color saturation (typically the red nebulae become pink) and even a complete saturation of the the brightner red nebulae. That's why we should darken the H-alpha image before putting it as the new lightness. The operation to darken the image strongly depends on each particular case; sometimes HDRMT works well, and sometimes a simple midtones or curves adjustment does the job. This process will minimize the loss of color saturation, which will be easily recoverable to the original state of the original color image with a simple curve adjustment in the S channel.
The other problem we face with this technique is the dramatic change of brightness of the stars. How you protect the stars and the reflection nebulae will change from image to image. In my workshop in Munich last year I showed three different examples on how to solve this problem, each one with different star masks. One of the examples was this one:
https://pixinsight.com/workshops/cfa-2014/munich-02.html
In this particular case I protected the stars in two ways:
- First I mixed the L component (or a synthetic L from the color image if you don't have L-filtered images) with the H-alpha image. A small amount of the L image will help to recover the dimmer stars, which almost dissapeared in the H-alpha image. For this example I used 20% of L and 80% of H-alpha; this proportion is a good balance between noise transfer from L to H-alpha (considering that usually the H-alpha image is much cleaner) and the effect on the dimmer stars.
- I created a mask to protect the stars. In this case I created the mask from the B channel of the color image because there were also some tiny reflection nebulae. The H-alpha introduction into the lightness of the color image should be regulated by this mask.
For your image, even if I haven't seen it, I would say that you'll need two masks. One that protects the reflection nebulae and another that protects the stars. If your star and reflection nebulae in both masks are bright (so you invert the mask when appplying the lightness introduction), you can mix both masks in PixelMaxh with this equation: Max( mask_stars, mask_nebulae ).
IMPORTANT: All these processes are applied to non-linear images!
My plan is to publish by the end of this year an article with a compilation of the best examples of my workshops during the last year. The example above will be one of them.
Hope this helps.
Best regards,
Vicent.
« Last Edit: 2014 July 26 05:21:28 by vicent_peris »
Offline Terry Danks
« Reply #4 on: 2014 July 26 08:40:44 »
Very helpful, Vicent. Thanks very much!
Looking forward to you publishing your workshop examples as well.
Terry
Offline lucchett
« Reply #5 on: 2014 July 27 15:18:45 »
Agree, very interesting.
It gave me one solution to handle my last image.
Thank you for sharing Vicent!
Andrea
