Author Topic: DBE question: how to use background model on different image  (Read 2308 times)
Offline lucchett
is it possible to re-use the background model calculated on one image?
I am not talking about the DBE settings to be applied to a new image, but the background itself.
I think a wrong flat created some gradients on the image, which are hard to remove because I cannot put samples where needed.
Many thanks,
Andrea
Re: DBE question: how to use background model on different image
« Reply #1 on: 2014 July 21 17:30:27 »
Hi Andrea, why not? Is the image full covereded by nebulaes? if not you can play with tolerance and also fixe values if needed.
Saludos, Alejandro
Offline lucchett
« Reply #2 on: 2014 July 22 02:02:04 »
Hi Alejandro,
the image it is a close up of the NGC 2264 @1016mm focal lenght.
it is hard to place the right samples.
The gradient comes from a bad flat and light pollution: light pollution is not severe but the integration time is long enough to make it noticeable.
I was thinking to find a way to get rid of the flat issue and then do my best for the light pollution residual gradient.
The image itself is an experiment (good ha data, RGB 2x2) so I am trying to find a quick way to fix data to a reasonable point before experimenting with the HaRGB blend (it seems difficult to blend ha data with  2x2 RGB...).
By the way, for now I have followed your suggestion and re run a model in DBE, which is "almost good".
thank you very much,
Andrea
