Author Topic: Deep M42  (Read 3895 times)
Offline avandonk
Deep M42
« on: 2014 July 11 12:50:50 »
Gathered all the data I had of M42 from last summer in RGB and hit it with PixInsight.
The data was about fifty frames each of RGB with four minutes exposure.
Large image x1.5 native camera pixel size. Here 20 MB
http://d1355990.i49.quadrahosting.com.au/2014_07/M42_PI_2.jpg
My observatory is only 16km or 10 miles from a large city, Melbourne. Light pollution and transparency is always a problem.
It was the DBE module that first attracted me to PI. I have been slowly learning far more about the use of PI and it gives me better results than anything I have been using in the past.
All data images were output at 32b FP after calibration.  Alignment and integration with drizzle x2. After combination of RGB used DBE to eliminate gradients and/or light pollution. MLT used to reduce noise much the same as ATW. I have found that HDRMT works far better on 32b FP data.
The take home message is that without PixInsight this image would not exist. All the interesting dim stuff would be hidden in the light pollution and gradients.
Bert
Astrograph is an Officina Stellare RH200 which has a focal length of 600mm and is F3. Clear aperture is 200mm.
FLI Atlas Focuser.
FLI ten position filter wheel CFW-3-10 with 50mm square filters.
Astrodon E series LRGB and HA, NII, SII and OIII 3nm NB filters. Also a continuum filter 5nm.
Camera is a FLI PL16803 which has a sensor size 36.8 X 36.8 mm.
The FoV of this system is 3.5 X 3.5 degrees.
Mount is a Software Bisque PMX.
Offline avandonk
Re: Deep M42
« Reply #1 on: 2014 July 14 14:00:25 »
M42 HDR version.
Data 40x30s of each of RGB
        50x4 min of each of RGB
I even worked out how to use the HDR composition tool to put the 30s and 4 min data together.
Full size drizzled HDR image 30MB
http://d1355990.i49.quadrahosting.com.au/2014_07/M42_PI_HDR.jpg
The optic train was not as stable and well aligned as it is now when this data was recorded.
PI tells me that this image has a dynamic range of a little over 19 bits.
Bert
Offline kolec
Re: Deep M42
« Reply #2 on: 2014 July 15 01:01:55 »
I like M42, I like big sensor 16803 , only two notes
1. place with low signal is very  noisy - in pix. resours are some examples (with mask , ...)...
2. stars in corner LH and RH is no good . I dont know what happend .
kolec
Re: Deep M42
« Reply #3 on: 2014 July 21 18:05:18 »
Hi Bert, Nice M42, I like this object!
You can try ACDNR to smooth the low SNR areas using the incorporated mask to protect stars and bright parts of the neublae.
Saludos, Alejandro.
