I'd like to confirm the correct workflow when using the BPP script to perform Bayer Drizzle on DSLR images. Does the following process flow look correct?
* Set up BPP normally, but make sure the Lights tab has Bayer Drizzle and Generate Drizzle Data checked.
* After the BPP script completes the folder structure will contain .drz files in the following locations
* $OUTPUT_DIR/registered - The files in this directory point to the DEBAYERED files
* $OUTPUT_DIR/registered/bayer - The files in this directory point to the BAYER files in $OUTPUT_DIR/calibrated/light/bayer
* Run ImageIntegration using the .drz files in $OUTPUT_DIR/registered/bayer and the registered light .fit files in $OUTPUT_DIR/registered with Generate Drizzle Data checked.
* This will update the .drz files in the $OUTPUT_DIR/registered/bayer directory.
* DrizzleIntegration should use the files in $OUTPUT_DIR/registered/bayer which will make use of the BAYER format files in $OUTPUT_DIR/calibrated/light/bayer.
* Here, we should use Scale factor = 1 and Drop Shrink = 1
* The generated integration file will NOT have gone through any debayering process, since there was enough data given to the drizzle processing to generate a complete RGB image.
Where $OUTPUT_DIR = the output directory defined in the BPP script
Thanks, Craig
