Author Topic: Drizzle  (Read 4110 times)
Offline litobrit
Drizzle
« on: 2014 July 06 10:36:56 »
Hello.
I am a new user of Pixinsight and of this forum. Sorry for my english  :P
I have made this M16 SHO a few day ago whith a RCGSO8 and an Atik 383 bin2, so the luminance Ha is under sampled.
I have tried the tuto of Juan about drizzle. Everything works fine except the last step when integrating drizzle files. The stars are clearly stretched by more than 10 pixels. :surprised:
Without drizzle the integrated image has good circular stars as you can seen on the final image :
Re: Drizzle
« Reply #1 on: 2014 July 06 16:06:26 »
I am not sure I understand the problem you are reporting. Drizzle cannot "stretch" stars as far as I know. How many frames are you integrating with drizzle? Which drizzle parameters?
Offline litobrit
Re: Drizzle
« Reply #2 on: 2014 July 06 23:29:49 »
Hello Juan. I am integrating 15 Ha frames.
Screen captures below :
Re: Drizzle
« Reply #3 on: 2014 July 07 09:06:13 »
No similar problem has been reported so far with drizzle. I can't say anything without having a look at the images. Could you upload them, so I can try to reproduce the issue?
On a side note, you shouldn't enable clip high range with drizzle; see the missing saturated pixel on a bright star in your last screenshot, near the top right corner of the drizzle integrated image.
Offline litobrit
Re: Drizzle
« Reply #4 on: 2014 July 07 10:01:42 »
Hello Juan,
Clip hight range will be off...
The calibrated frames are here :    https://www.dropbox.com/sh/x33mve6g4nkoujo/AAA8m4LpAnw9whGFYWAtoYewa
Thanks for your help
Re: Drizzle
« Reply #5 on: 2014 July 08 02:38:55 »
Bug confirmed. DrizzleIntegration does not apply correctly the image registration transformations when there are images rotated by 180 degrees in the original data set. I am working right now to fix this bug ASAP. Thank you for uploading your images.
While I fix this problem, the workaround is simply to rotate the necessary images by 180 degrees before StarAlignment. In this specific case:
- Open the ImageContainer tool.
- Select your images from M16-008H_c to M16-015H_c, both included
- In the output template, write: &filename;_r180&extension;
- Open the FastRotation tool, and make sure the rotate 180 degrees option is selected.
- Drag the ImageContainer blue triangle to FastRotation's control bar.
- Proceed to register, integrate and drizzle your files as usual, but use the _r180 images created above.
Sorry for the inconvenience. This bug will be fixed through an update as soon as I can.
Offline litobrit
Re: Drizzle
« Reply #6 on: 2014 July 08 04:11:03 »
Hello Juan,
Happy to participate to Px improvement.
I have tried this morning with another set of frames without 180° rotation. Drizzle is working fine. Noise is greater than normal integrated images but seems easier to manage. Definition is better.
Re: Drizzle
« Reply #7 on: 2014 July 08 06:56:21 »
I've got good news: this bug is now fixed. I'm preparing an update for all supported platforms, which I'll release later this afternoon. Thank you again for your help and patience.
Re: Drizzle
« Reply #8 on: 2014 July 08 10:14:54 »
The update is now available. Let me know if everything works correctly.
Offline litobrit
Re: Drizzle
« Reply #9 on: 2014 July 15 03:52:34 »
Working fine.  :)
