www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
increasing detail in RGB only (no L) images
« previous
next »
Print
Pages: [
1
Author
Topic: increasing detail in RGB only (no L) images (Read 3151 times)
urbanMark
Newcomer
on:
2014 July 01 00:09:29 »
I'm playing with an R+G+B only image I took of M16 and wanted to see what I could do to increase detail. First I tried the new drizzle function and was very impressed (original image scale was 1.98 arcsec/pixel, applied 2x drizzle). But I wanted even more, so since R subs had the most detail I decided to try re-using the R channel as L. This produced great results as well, but created halos around the bright stars. I then went back to just RGB and tried getting the same result by boosting the L channel in curves, but could never get quite the same result.
So what is the best way to get the most detail out of an R+B+G only image?
RGB + R re-used as L -
http://www.astrobin.com/105004/
Mark
Logged
MikeOates
PixInsight Addict
Re: increasing detail in RGB only (no L) images
Reply #1 on:
2014 July 01 07:14:28 »
Hi Mark & welcome to the forum.
Instead of just using R as a luminance channel, produce your RGB image, then extract the L from that. Work on the L image to increase detail and then recombine with the RGB using LRGBCombination.
Logged
jsines
Newcomer
Reply #2 on:
2014 July 01 22:02:17 »
Another option that Vicent taught at the recent CfA PI forum is to combine all of your R, G, B frames into a single image, and use that as your Lum frame when combining Lum into RGB.
Logged
Orion ED80T
Orion Sirius mount
Orion SSAG and PhD2
SBIG ST-8300M and FW5-8300
Alejandro Tombolini
PTeam Member
PixInsight Jedi
Reply #3 on:
2014 July 02 03:55:21 »
Hi Mark, you can also see the processing examples
here
, most of them are RGB images. And also
M16
which has the option to download the integration and follow the process.
Saludos, Alejandro.
Logged
Warhen
PTeam Member
PixInsight Old Hand
Reply #4 on:
2014 July 08 10:43:27 »
Remember too Mark that many enhancement tools can be targeted directly to the Lightness channel.
Logged
Best always, Warren
Warren A. Keller
www.ip4ap.com
Print
Pages: [
1
« previous
next »
PixInsight
General
