Author Topic: How do I add images within a post?  (Read 2500 times)
Offline MikeOates
« on: 2014 June 15 07:10:43 »
I am trying to put together a Processing Example / Tutorial to add to the Tutorials and Processing Examples section. But I can't add images to the post. I have uploaded all the images to the endor server and I want to link to those, showing either a thumbnail image to click on to show the full size, or just to display the image.
I want to add an image then some text, then another image etc. I don't want to attach images as they all end up at the bottom of the post.
When you use the add image icon in the topic edit window all it does is insert "" and putting an image path in there just shows the path and not the image when I preview the post.
An example path to the endor server follows:
<img width="480" height="260" src="http://endor.uv.es/files/data/public/3b523d.php?dl&true&ct=true">
Re: How do I add images within a post?
« Reply #1 on: 2014 June 15 08:28:32 »
You have to use the following sintaxis:
[img]http://theurlofyourimage[/img]
« Reply #2 on: 2014 June 15 08:30:11 »
Example:
[img]http://endor.uv.es/files/data/public/3b523d.php?dl&true&ct=true[/img]
Offline MikeOates
« Reply #3 on: 2014 June 15 08:38:01 »
Carlos,
Thank you very much.  :)
