Author Topic: Auto-save PSM not working  (Read 3118 times)
Offline cs_pixinsight
« on: 2014 June 07 08:41:30 »
Yesterday I finally upgraded to Ripley and everything seems to be working as expected except for the autosave of process icons on the workspace.  My PC crashed for some reason last night after I left PI open with some unsaved processes I used during testing.  I thought, no problem I'll just go get the backup file in AppData/Local/Temp, but there were no files except those left over from version 1.7.
This morning I did some tests with this and PI 01.08.01.1092 on Windows 7 x64 is not saving even with the autosave setting in global prefs indicating it should every 30 seconds.  Is there some other dependent setting that I have forgotten about to get this working?  I'm fairly certain that is not the case, but wanted to ask to be sure.
Craig
Re: Auto-save PSM not working
« Reply #1 on: 2014 June 09 00:37:31 »
Hi Craig,
I can't reproduce this issue. I've just tested and PSM AutoSave works correctly on all platforms.
Keep in mind that PSM files are saved on the current swap directory. This is not necessarily the system's temporary files folder if you have customized it via Preferences.
