Thanks Bitli,
The darks I was using were taken with the same acquisition program, but were intended for use with a different processing program, which recommended that scaled master darks be at least 5 times longer than the lights. So my master dark was built from 1 hour subs, since I usually take 10 minute light subs.
I am in the process of redoing my darks with 10 minute subs and, if I keep the temperature stable for another two hours, I'll try again with those. Even if they don't work for PixInsight's optimization algorithm, I can still use them directly, non-optimized.
- Shane (rapidly learning more and more about PixInsight!)
