Author Topic: using previews in pixelmath expression  (Read 3552 times)
Offline astroedo
  • Io ne ho viste... cose che voi umani...
    • L'arciere celeste
« on: 2014 June 05 01:39:28 »
Hello all,
Is it possible to use previews in PixelMath expression?
For example I would like to evaluate the background of the image so I can use the median level of a patch of sky.
I would like to create a preview on my image an use it with the med (image) function of pixinsight without cloning the preview in a new image.
Edoardo
Re: using previews in pixelmath expression
« Reply #1 on: 2014 June 09 00:41:21 »
Hi Edoardo,
PixelMath works with main views, not with previews. You can of course apply PixelMath to a preview, but you cannot use a preview in a PixelMath expression.
You can make an independent image from a preview (PREVIEW > Make Image, or just drag a preview's view selector anywhere on the workspace) and then use its name in PixelMath expressions.
Offline astroedo
    • L'arciere celeste
« Reply #2 on: 2014 June 09 04:03:04 »
Thank you Juan for reply.
The "drag and drop" technique is the one I'm using now and it works well.
My goal was to create reusable "script-like" PixelMath icons without the need for creating a new image from preview used for median or mean estimate.
......I will begin to study for learning java script  :D
Only for curiosity: it would be difficult to implement the "preview support" for pixel math?
Offline mschuster
« Reply #3 on: 2014 December 18 08:50:08 »
I would like to add a wish list for this. It would simplify PJSR scripting by avoiding the need to create and manage temporary images.
You can of course apply PixelMath to a preview.
Open an image, change its Id to "A". Create a preview in A. Apply the PixelMath expression "A" with "Create new image" to A's preview. PixelMath generates no image nor an error message (i.e. size mismatch?). Bug?
« Last Edit: 2014 December 18 08:56:43 by mschuster »
Offline astroedo
    • L'arciere celeste
« Reply #4 on: 2014 December 18 09:06:02 »
In my experience create new image never works with previews.
This is not a BUG in my opinion because previews are intended to preview ( :D ;D ) the result of the expression before applying to the whole image.
« Reply #5 on: 2014 December 18 09:13:51 »
No bug. It works this way by design. As Edoardo says, the preview in this case reproduces the result that you would obtain as a new image if you applied the instance to the main view.
