Author Topic: New DrizzleIntegration Tool Released  (Read 131104 times)
Offline erikgu
Re: New DrizzleIntegration Tool Released
« Reply #60 on: 2014 July 30 22:48:11 »
Hi Juan,
There must be somthing i dont understand with flats could you please explain why needing specific flats for meridian fliped images.
Your master flat overcorrects the upper left corners of your light frames. Also you have some light frames that are rotated by 180 degrees due to a meridian flip. These frames require a specific flat and are obviously not being flattened well.
Erik G
Offline cfranks
« Reply #61 on: 2014 July 31 04:29:20 »
I enclose a small, highly magnified section of a without- and with- Drizzle using a QSI 540 camera on a Takumar 6x7 150mm lens.  The difference is astounding.  Many thanks Juan for this superb implementation!  Only defaults were used.
Offline mschuster
« Reply #62 on: 2014 August 05 19:39:37 »
When doing a StarAlignment with Generate drizzle data set and with a Projective Transformation registration model, is the Interpolation method (Auto, Bicubic Spline, ...) have any effect on the drizzle results? I am thinking no (i.e. drizzle does not require this sort of interpolation) but maybe I am wrong.
Offline Dimitris Platis
« Reply #63 on: 2014 August 06 03:45:11 »
I would like to inquire regarding this new tool which I have used successfully I might add.
There is seems to be some complication when I transfer the data from one PC to another. Somehow, the drizzle files are looking for the original path where they where first created and even though I define the present path (for example during Drizzle integration) the process fails.
I have to do Star Alignment again in order to create the files again in a new directory in the new PC in order to run Drizzle Integration.
Is that normal?
« Reply #64 on: 2014 August 06 09:44:41 »
As you have guessed drizzle does not require or apply any pixel interpolation, so the pixel interpolation algorithm used for image registration has no direct effect on drizzle. However, you need to generate temporary registered images to integrate them in order to update the .drz files with pixel rejection data. Hence, the pixel interpolation algorithm used for image registration has an indirect, small but non-negligible effect on the final drizzle-integrated image due to rejection. Perhaps—but I have not tested this—using an interpolation less prone to ringing than Lanczos, such as bicubic or even bilinear, would make sense for drizzle.
« Reply #65 on: 2014 August 06 09:54:06 »
On the DrizzleIntegration tool, open the Format Hints section and specify the folder where you have stored your data files in the Input directory field (yes, I know, not the best/most intuitive place to put this parameter...). The input directory that you specify will override the original paths stored in the .drz files. This will allow you to move your drizzle data sets freely across filesystems and machines.
Offline mchaser
« Reply #66 on: 2014 September 21 07:51:55 »
Thanks to all who worked on this.  The results are very impressive.  I have one question.  Why  do some images come out of the drizzle integration tool with a rotation, while others do not?  It's making it tricky to stitch together my mosaics.
Offline MortenBalling
« Reply #67 on: 2014 September 30 07:54:57 »
This tool is awesome, and I highly recommend trying it on your images.
I've been using a cowboy trick where I rescaled my reference image to 200%+ before registering, but this is way better. I did a small test, using 104 light frames, and after drizzling, I resampled the drizzled image back to normal size, and compared with the normally integrated image. The SNR increased by drizzling from 278 to 412, equalling more than double the amount of exposure time.
I was easily able to see a mag19.3 z=0.77 QSO that was drowned in noise in the normal integration.
Cs
Morten :)
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #68 on: 2014 November 02 02:35:16 »
Juan
This tools is amazing !!! Even for 15-20 images only !!!
Main goal for me is not oversample the image (it is already 4k x 4k ) but generate a 8k x 8k image to have better star shape and roundness. Then make star reduction and processing, then shrink to 4k x 4k image. This is great !!!
Something I saw during the process :
I make StarAlignment with files calibrated then get suffix "CAL"
I make ImageIntegration with files "CAL-R" and CAL-R.DRZ files
I make DrizzleIntegration with CAL-R.DRZ files
and I see Drizzle tools uses original "CAL" files and not aligned ones ? I think this is better because no interpolation is added twice ?
Do you confirm this use ?
Many thanks
Philippe
« Reply #69 on: 2014 November 02 03:00:47 »
Yes. We have to avoid doing interpolation, but we need the transformation matrix from SA to make the pixel coordinates match.
Offline IanL
    • The Imaging Toolbox
« Reply #70 on: 2015 November 06 11:43:34 »
Note that there is now a new BayerDrizzlePrep script available for testing here:
http://pixinsight.com/forum/index.php?topic=9218.0
This should make it possible to perform stand-alone Bayer drizzling more easily, without the need for the BPP script.
Offline wangc5
« Reply #71 on: 2016 December 07 06:10:11 »
Can this be integrated into the integration tool so that we don't have to do two steps (integration and drizzle integration)? Or is there a script to do both steps? Thanks!
Chunyu
Offline RickS
« Reply #72 on: 2016 December 07 16:09:55 »
I don't think it makes sense to combine the two operations.  It is best practice to run ImageIntegration multiple times to adjust the rejection parameters.  It doesn't make sense to run DrizzleIntegration until after that's done.
Rick.
« Reply #73 on: 2016 December 08 01:12:07 »
Along with what Rick says, that would be a clear breach of one of the most important design principles of PixInsight: Modularity.
Offline jerryyyyy
    • Astrobin Images
« Reply #74 on: 2016 December 12 12:00:33 »
Guys, have just come back to using this again on some images after having mastered MureDenoise.  As you note the images may get a touch nosier, so I tried to apply it and my default setting for my STT 8300M do not work... they produce the checkerboard pattern.  If I had gotten this in the past, I was able to hack the settings to get it to work, but I cannot achieve good MureDenoise.
Can any of the math wizards explain this to me (actually I am less in interested in the explanation as I am is denoising, so a quick hack would also be appreciated)  >:D
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
